Moving from TX to CO, should I retune when I get there?
Old Feb 6, 2024 | 09:08 PM
Red Dragons's Avatar
Red Dragons
Question Moving from TX to CO, should I retune when I get there?
2013 FXDF with PV tuner...running a closed loop tune. Should I redo my basic autotuning at the new altitude, or just let closed loop do its thing?
Old Feb 6, 2024 | 09:55 PM
Lonewolf176's Avatar
Lonewolf176
Depending on the elevation I may make some adjustments to the main lambda and spark tables tables first. I would also check that your map sensor is calibrated, if you have that table.
Old Feb 6, 2024 | 10:01 PM
Red Dragons
How would I verify the map sensor is calibrated? It is 11 years old now, so perhaps I should just replace it?
Old Feb 6, 2024 | 10:24 PM
Lonewolf176
Sea level is 100 kpa +/-. At 6000' it's 81 kpa +/- so at this kpa you're not going to reach the higher kpa values on those tables. I do a few bikes for guys that do some stunt riding and they have a second map they can use at higher elevations where I move the higher kpa colums to the left to match the max kpa for that elevation. eg. 100kpa values over to 80 kpa. Is this right I don't know but it seems to work.
It's not so much about the sensor being wore out. The ecm "sees" the kpa. This is about calibrating the ecm to see the actual value. It's common to see it off by 6 +/- %. Do a data log of wot to see how it compares to actual. If you have a table like this you can adjust to make the ecm see the actual. Just another thing to do when tuning. Hope all this makes sense.
makes sense.
Old Feb 6, 2024 | 10:29 PM
Red Dragons
Interesting, I'll look into it. I guess I'm wondering how stock bikes work at higher elevations without making any changes like this.
Old Feb 6, 2024 | 10:33 PM
03fattyaz's Avatar
03fattyaz
Just make the move then see how it runs.
Old Feb 6, 2024 | 10:41 PM
Red Dragons
Thanks fatty.
Old Feb 6, 2024 | 10:45 PM
Lonewolf176
Yup but depending on your elevation open your map and compare requested values between columns. High enough elevation and you'll notice less power because of less air but that's out of our control. Just look at the sae correction factor on a high elevation dyno sheet.
Old Feb 7, 2024 | 11:57 AM
Red Dragons
I'm gonna be living in Denver but obviously will want to be able to go into the mountains without issues. Seems like the O2 sensors would take care of adjusting the afr with altitude, no?
Old Feb 7, 2024 | 12:18 PM
KK0G's Avatar
KK0G
No you don't need to retune. Electronic fuel injection by it's very nature is already continuously compensating for mixture changes due to changes in elevation, barometric pressure, ambient temperature, etc. Think of it this way, there's hundreds of thousand times as many electronic fuel injected cars and trucks on the road as there is motorcycles and nobody retunes them going from low to high elevation or vice versa. You will loose horsepower going up in elevation simply because there is less oxygen to burn but short of a turbo charger there's nothing you can do about that.
