Diag codes
Old Mar 8, 2024 | 07:54 PM
Doublefelix's Avatar
Doublefelix
Default Diag codes
2022 fatboy. Bar swap a year ago.
All of a sudden I'm getting a rev of the throttle interermittenly and i think it is when bars are turned left. Llike when taking a left turn from a stop.
Also getting check engine with codes
P1510 EFI Limited performance mode
P2138 TGS voltage correlation error
B2161 Brake lamp output open
So... wire extension? Twist grip? Why would the stop lamp code be there?
Old Mar 12, 2024 | 08:58 AM
bustert's Avatar
bustert
the twist grip has been an issue. there are two counter acting circuits that acts as a check/balance
the machine will go into limp mode on several upsets and the throttle is one.
electrical connection is the first KISS
the b2161 could be related to the brake pressure switch, i had two failures, finally replace with an automotive one with a larger diaphragm.
1meangt
Nov 18, 2023 07:32 PM
JonnyVegas
Aug 12, 2018 09:55 AM
John Kurz
Mar 31, 2018 05:55 PM
geopac
Feb 21, 2016 12:39 AM
