2016 Dyna Starting Issue
Old Jul 2, 2025 | 07:47 PM
benny.d's Avatar
benny.d
Default 2016 Dyna Starting Issue
2016 Dyna Switchback with an intermittent starting issue. I went for a ride today with no issues. When I went to start the bike back up after getting gas it would not start. Clutch was pulled and the bike was in neutral. Run/stop switch was in the proper position. I could hear the fuel pump turn on. Then when I hit the starter button I just heard a humming noise that sounded like the fuel pump. The lights dimmed. I didn't hear a click like I normally would with a dead battery. I turned the bike on/off a few times and eventually it started. When I got home I shut it off and it started right away. Then I shut it off again and had the same issue.
I checked the battery connections at the gas station and they are good. I am going to check battery voltage and charge if needed after finishing this post.
Only other thing I can think to do is clean the contacts in the housing.
Any other ideas?
Old Jul 2, 2025 | 08:09 PM
Addicted to Chaos's Avatar
Addicted to Chaos
Starter relay?
Old Jul 2, 2025 | 08:19 PM
benny.d's Avatar
benny.d
Originally Posted by Addicted to Chaos
Starter relay?
I looked into that on the forum. This is what I found:
"No starter relay like older models; Starter Solenoid Power is provided by the BCM (Body Control Module)"
- @FXD2003Rider
Old Jul 2, 2025 | 09:54 PM
Addicted to Chaos
Learned something today! This is what my 2011 fuse box looks like. Mistakenly thought yours would be the same
Someone else should have some advice for you.
Old Jul 2, 2025 | 11:43 PM
Max Headflow's Avatar
Max Headflow
I hate to say this but did you get any codes..
One thing you can do is bypass the BCM by jumping between starter control connection on the solenoid and the battery cable running to the solenoid. Motor should crank. Make damned sure the bike is in neutral as all safeguards are disabled.
Old Jul 3, 2025 | 09:39 AM
benny.d's Avatar
benny.d
I'll check codes once I put the battery back in when I get home from work.
Old Jul 3, 2025 | 09:55 AM
Screamin beagle's Avatar
Screamin beagle
How old is the battery? Should have it tested regardless.
Old Jul 3, 2025 | 09:56 AM
benny.d's Avatar
benny.d
Purchased in May 2025
Old Jul 4, 2025 | 12:50 PM
benny.d's Avatar
benny.d
So I got it narrowed down to it will only start on the kickstand and won't start standing up.
Threw error code B2123.
I checked the battery. For some reason, when the dealer installed my lights, they took the spacer out of the battery box and never reinstalled it. I'm guessing this is what made it so positional.
I put a spacer back in the box and so far so good.
Just wanted to follow up for anyone who needed this advice in the future.
Riku5670
Dec 28, 2023 09:14 AM
Dtee
18
Feb 9, 2023 09:19 PM
jcubnatn
Apr 29, 2018 11:13 AM
scrookie
Mar 25, 2014 03:08 AM
mikeagordon02
Jul 28, 2012 12:03 PM
