MAP sensor
Old Nov 21, 2025 | 07:34 AM
im's Avatar
im
How is the voltage regulator on that bike?
Old Nov 21, 2025 | 08:45 AM
bustert's Avatar
bustert
mr. im makes a valid point
in electronics, the rule of order is check power supply. things go wonky when power is not right. most sensors today use a lower source, aka 5 volt, since tech has gone wayyyy past transistor logic which typically was 12 volts. higher voltage is used in power where as lower in for control, wayyyy easier to trouble shoot. the same goes for ground source since it is easier to find a positive potential than a negative since most are referenced to engine ground. HOWEVER, that does not mean everything is ground sourced since you can have a so called ground source with two positive potentials.
one of the biggest concerns is in how clean the power supply is. in the analog, hash was tolerated but not so digital because because hash can mess up the logic and computers are stupid, can only do as commanded. that said, i would check for excessive AC ripple. you will always have some but the battery is like a giant capacitor and will absorb it.
case in point: when digital came out, chrysler has serious issues as the vehicle got older, why??? well, the alternator still used segmented armature and as it wore, the output was spiked and that introduce hash which overwhelmed the system and made diagnostics hard until they found out the issue, so now the alternator has slip rings.
bad grounds and iffy connection are a common issues. today, data logging is most important but most do not have the $$$$$ equipment so shops make $$$$$.
Old Nov 21, 2025 | 11:14 AM
GlennJ's Avatar
GlennJ
Good as far as I can tell. Voltmeter shows proper function while running, no idiot lights, no codes thrown other than "MAP sensor failure"
Old Nov 21, 2025 | 11:20 AM
GlennJ's Avatar
GlennJ
And now I have a minor headache...
I do like to learn though.
Old Nov 21, 2025 | 09:02 PM
im's Avatar
im
Use a digital voltage meter at battery terminals to review DC voltage.
Do not use a dash meter.
With the bike parked..
Check voltage before starting with everything OFF and write down voltages.
Then write down voltages for:
While cranking.
At low idle
At a steady high RPM.
When you have checked the above then go back and check if AC voltage is slipping to battery.....yes AC voltage while the bike is at low idle and then a steady HIGH RPM.
Old Nov 22, 2025 | 08:16 AM
bustert's Avatar
bustert
take two naprosin
this can and is a DEEPPPPPPP subject!!!!
sooooo many ways to skin a cat, aka, toooooooo many systems!!!
want to really hurt, try boolean algebra.
Old Nov 26, 2025 | 05:08 PM
Max Headflow's Avatar
Max Headflow
The map sensor gets 5 volts from either the ICM or ECM..
Old Nov 26, 2025 | 05:14 PM
Max Headflow
Originally Posted by Ed Ramberger
Remember, codes do not mean failed parts - they mean a circuit problem. So it could be a failed part, a wire, a connection. You may very well have a bad MAP sensor, but don't want you to think that codes mean parts as that will bite you in an expensive way one day.
Yeah, Like bad 5 volt supply.. Either connection or source.
Old Nov 26, 2025 | 05:52 PM
GlennJ's Avatar
GlennJ
Understood. Wiring appears OK on a visual inspection, sensor showed up today so I'm going to install it and see. Even if it is a power supply problem the sensor has 150k miles on it so it won't hurt to have a new one.
I have the multimeter but am working alone and some of the recommended output checks (specifically readings at variable throttle settings) would be easier done with two people.
Appreciate all of the advice, I will report back as to what the problem turns out to be.
Old Nov 26, 2025 | 06:28 PM
Max Headflow
At 150,000 miles, You need to tug on the 5 volt wire at every connection or possible place it might bend or flex.. If the wire stretches, you got a brake.. The wire will look good on the outside but can be broken on the inside.
Years ago a friend has an EVO FXR that was having electrical problems with over 100K one it. We split the harness cover at the steering neck and started pulling. We found 3 wires that had the copper wire shredding inside.. On was pretty bad but the others had enough overlap that they still made contact, sort of.
Based on the wiring diagram, the only other sensors are intake temp and 1/2 of the TGS power. You want to check sensor voltage 2, sensor ground 2 and the Map signal wire.
It may be the TMAP. It may be grounds to the ECM..
