Let's talk about fuel injetors
I want to learn more about fuel injectors regarding size and duty cycle. I have tried doing a search in this sub-forum and went back several years and can't find anything.
So please help answer questions. I'm SURE there are MANY other people here that don't know and would like to know as well.
First off, while it seems like it would be simple, please explain about size of injector. The stock engine has 4.3gps injectors. Does that mean that in a wide open stream/spray, the injector would dispense 4.3 grams per second?
And compared to the 5.5. So the 5.5 is bigger. Now, unlike a carburator where it is just dumped into the manifold, please explain that if the engine signals for fuel, and the injector responds, how is not having more fuel better?
Yes, I understand it could choke it out. I'm old school engine builder. A Holly 850 double pumper, manual secondaries would bog out a small block 289. A built 454 would use every ounce.
I'm also trying to understand the duty cycle of the injector. My next stop is YouTube. But for the benefit of the audience here, please explain.
I understand that when the duty cycle reaches above 85%, a bigger injector should be installed. On the opposite end, what does it mean when the duty cycle is too low?
TIA,
TIA,
fact can make the engine run worse at slow rpms. And your right , 80-90 % duty cycle is when you should consider moving a size up.
we go into great detail on fuel injectors; sizing, monitoring duty cycle, design, & tuning.
https://www.fuelmotousa.com/p-34004-...lepodcast.html
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Gps = grams per second
Lb/Hr = pounds per hour
CC = Cubic centimeter
For best fuel control you want to use the smallest flow injector that will get the job done as it will give you the best drive ability and fuel economy. That said using a injector with a single spray pattern on a 4 valve head is just dumb but people are selling just that to the public all the time. A perfect example is back in 2006 when HD factory used an injector that had the spray cone angle of 8 degree's in the stock bikes. Once they hit the public people started complaining of having drive ability issues, unstable idles and Cold start issues. HD changed the injector for one that was the exact same in terms of flow but the spray cone angle was change to 25 degree's along with a new calibration to support the injector change and all the issues disappeared. So it is NOT just a flow rating that people need to be aware of!
Injectors DO NOT flow the same across the entire operating range! If you were to look at the flow at very low pulse width and again at very High pulse width things change, and this is just why the industry as a whole uses a 80% rule on injectors. If you do real measurement an injector has a very linear output provided you stay within the 80% DC range. Go outside of this range and things become unstable and unpredictable. A simple example would be you increase the pulse width 5 % and the injector flow will increase 5 % within the 80% range outside this range............... who knows
Thank you to Steve, @stroisi12 and @fuelmoto .
Thank you to the ones who know. I appreciate the simple facts, albeit very technical and I am sure other new people are learning as well.
Helping others to understand that a 4 hole is better, the angle make a difference, and bigger is not always better.
