One More SERT Question
Old Sep 29, 2007 | 03:26 AM
mrbadlands's Avatar
mrbadlands
Default One More SERT Question
Hi All,
I have spent many hours searching the forums here and if my question has been answered, I failed to recognize it.
I recently purchased an 07 Roadking and yes, I have all the symptoms that people cmplain about. BUT, the only real thing I am looking to correct at this time is the heat issue. What I would really like to do is get the SERT and load a map with "stock" configuration that may address the heat issue. Then in due time when I feel like I am ready to pull the trigger on a stage 1, I will already have the SERT.
My question is, "Is there a canned map included on the CD that is for a bone stock configuration?"
mrbadlands
Old Sep 29, 2007 | 04:11 AM
Black Bart's Avatar
Black Bart
Default RE: One More SERT Question
Badlands,
No, I don't think you'll find a bone stock canned map in the SERT cdrom. But even if it had one I doubt you'd want to use it. To lower your temps you need to richen the mixture. So, I'd suggest installing the map for your model that has the stage1 mods done to iteven if you don't have them yet. In this way you'll have a richer mixture and less heat. Just my $.02.
Bart
[IMG]local://upfiles/16365/B50CA84A9AE74CC497C1D966D6221F94.jpg[/IMG]
Old Sep 29, 2007 | 12:53 PM
mrbadlands's Avatar
mrbadlands
ORIGINAL: Black Bart
Badlands,
Thanks Bart!!
I guess I had never heard someone here question about adding a SERT to a bike with no mods to specifically address the heat issue. I never realized that a canned map for a Stage 1 would be ok to put on a bike with no mods.
Thanks Again!
Royce
Old Sep 30, 2007 | 12:31 AM
hasselbach's Avatar
hasselbach
Send me an email and I will send you a map that may work for you. There are no maps for the 07 that will cool your bike. The 07's work on closed loop when the AF mixture is set to 14.6. So what we have done is make maps that go into a open loop to cool the motor and richen it up.
Send the email to hasselbach@adelphia.net, and I will forward you a specific map that should work for you.
Old Sep 30, 2007 | 12:03 PM
mrbadlands's Avatar
mrbadlands
Thanks Hasselbach!
An email has been dispatched your way.
arcticrider
Jan 16, 2011 01:21 PM
pauly_2
Oct 13, 2007 01:59 PM
UltraKla$$ic
44
May 3, 2007 10:15 PM
KBFXDLI
Nov 24, 2006 03:37 AM
twstdharley
Exhaust System Topics
Feb 6, 2006 11:18 PM
