Eletrical Problem FLHTC
Old Oct 8, 2007 | 08:27 AM
RoadGuard's Avatar
RoadGuard
4th Gear
Default Eletrical Problem FLHTC
I tried to start the bike and starter starts chattering but after a couple attempts it would grab and turn over once or twice. I never did get it fired up. After 5 or 6 attempts, my CLUTCH cable wasHOT to the touch at the handle bar area and I think something melted because it stick pulled in. Maybe a ground cable came off and the clutch cable was the only return path. Has anyone else had this happen?
New to post
Regards,
RoadGuard
Old Oct 8, 2007 | 10:28 AM
Dr.Hess's Avatar
Dr.Hess
Default RE: Eletrical Problem FLHTC
I've never heard that, but your assessment sounds reasonable. Check the ground cable. On my FLHT, it is under the bike, if I recall. Also sounds like you'll need a new clutch cable.
Old Oct 8, 2007 | 11:13 AM
drdiesel1's Avatar
drdiesel1
This is a very good possibility. I have had shifter cables weld together like that when the ground strap has been damaged or removed by someone.
It becomes the new return path as you suggest. I would give the electrical system a good inspection and make sure all my grounding points are clean and tight.
I would also make sure all the battery connections and starter connections are clean and tight as well. After you track down the cause and correct it. You`ll need a new clutch cable as well....[:@]
Very good failure analysis.
DanHappy
40
May 28, 2019 12:30 PM
Jefferyltaylor
May 2, 2014 12:23 AM
Bleachey
EVO
Sep 3, 2011 09:18 PM
hijo202
Sep 25, 2008 08:40 AM
blk06rk
Feb 28, 2006 08:14 PM
