Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
The wire would need to be an activation control circuit to cause a battery draw. Like a ground signal. The most common battery draw on today's auto/motorcycleelectrical systemscomes from stuck/sticking relays or A/M add on audio video systems.
How old is the battery and do you have/use a battery tender when the bike is not used for short/long term non-operational conditions.
What electrical modifications have been done if any.
You very well could have a failing battery. When was the last time you operated the bike. You also need to know if the charging system is functioning properly.
A grounded power wire would blow a fuse or melt the wire. This would not cause a sustained battery voltage draw.
Thanks for the replys, here is a link to another post about my problem,(https://www.hdforums.com/m_2273776/m...tm.htm#2291597) if you have any further advise for me. I have done all the work myself to date on the Dyna, but electronics is not one of my strong points.
A quick update, the bike is holding charge after I have bundled up the data cord and zip tied it neatly and securely. It did have some pinch marks on it, so from the responses received, I am considering that as the likely culpritt.
