PC map change
Old Dec 13, 2005 | 07:00 PM
barrygreen's Avatar
barrygreen
Default PC map change
Ok l reset my TPS value to 0 in the PC Now I want to try another map.
Do you have to reset the TPS if you change maps or just upload the new map?
Thanks
Barry
Old Dec 13, 2005 | 07:18 PM
airfuel's Avatar
airfuel
Default RE: PC map change
No need to reset when you load maps....it is set forever now.
Just load the maps and try them out. hope you find a good one.
John
Old Dec 13, 2005 | 07:43 PM
barrygreen's Avatar
barrygreen
What about if you remove the PC...disconnect it?
Old Dec 13, 2005 | 08:09 PM
airfuel's Avatar
airfuel
Doesn't matter, when you turn of your bike, all power is removed from the PC, same as disconnecting it from the bike.
OTOH, now that you know how to check it, do it once in awhile for kicks.
John
Old Dec 14, 2005 | 11:32 AM
dchoran's Avatar
dchoran
What does this TPS reset do???
Noticed mine was at -2???
THANKS
dchoran@athenet.net
Old Dec 14, 2005 | 02:24 PM
airfuel's Avatar
airfuel
The TPS reset just makes sure the Power Commander and the bikes TPS are in synch with each other so the map on the PC is reading correctly.
For example. If your bike is reading -10 at idle, when you are cruising at 20% throttle, the PC will think you are running at 10% throttle and read the wrong part of the map.
Small discrepencies will not hurt as the PC interpolates many values at every Throttle position.
John
Old Dec 14, 2005 | 02:40 PM
barrygreen's Avatar
barrygreen
airfuel is right and it makes a big difference, at least I could tell on mine...it was off 8%
Old Dec 14, 2005 | 03:01 PM
dchoran's Avatar
dchoran
AWESOME!!!
THANKS guys for the info. May help my 38 down to 32 MPG issue.
First I have ever heard of this THROTTLE POSITION THING!!!
What exactly do I need to do???
Connect my laptop to the PCIII, reload the map or just reset the position to zero??? What about that little bit of slack in the throttle???
Does my bike have to be running???
In the PCIII software the "set thottle position" is greyed out - probably until i connect right???
How do you actually set the zero point then???
THANKS AGAIN!!!!
Old Dec 14, 2005 | 03:13 PM
airfuel's Avatar
airfuel
Easier than me explaining, go here:http://www.powercommander.com/tut_download.shtml
Then under PCIIIUSB look at the tutorial on "how to set throttle values." Just reset the zero one.
tutorials go slow so be patient.
John
Old Dec 14, 2005 | 03:44 PM
barrygreen's Avatar
barrygreen
One thing, after I pushed the reset button the TPS value did not change to 0
untill I closed the Set TPS window then it went to 0. Yes the bike has to be
running and warm.
Have Fun!
Barry
Justinf74
Feb 27, 2012 08:30 PM
roaddog
Fuel Moto / Jackpot Mufflers
Feb 21, 2011 05:09 PM
tdshepard
Jan 26, 2010 09:41 PM
newdep332
Oct 24, 2008 01:13 PM
kproray
Apr 28, 2006 12:16 PM
