Is This True?
Old Nov 26, 2007 | 12:12 PM
Renegade1's Avatar
Renegade1
Default Is This True?
I havewondered why Dynojet does not add fuel to the 0% cells at idle for cooling purposes,(Traffic) and found the followingon the Nightrider site. Is this true, does the stock ECU set the AFR at 12:1 at idle when the O2 sensors areeliminated. Thanks.
The use of O2 eliminators has become fairly common on the 2007 engines. When using an O2 eliminators supplied by PowerCommander, TFI, V&H Fuel Pak, etc., the engine idles at a very rich 12.0:1 AFR. This will reduce the engine temperature, but also reduces gas mileage 3-5MPG on an FLH and can result in excessive carbon buildup in the combustion chamber.
Old Nov 26, 2007 | 02:23 PM
Doc 1's Avatar
Doc 1
Default RE: Is This True?
I haven't seen any SERT maps that have the 02 sensors on in the 0% TP....The sensors are usually off until 20kpa. The Fuel table has the AFR at 13.0 to 12.5 in the 0% column, some times it's at 13.5...it depends on the bike.
LonewolfFrank
Nov 16, 2015 08:23 AM
Reaper22
May 1, 2013 08:48 PM
Comingapart
Exhaust System Topics
Jul 14, 2010 10:50 AM
abrailman
Mar 6, 2008 05:32 PM
BIG6Y
16
May 19, 2007 05:01 AM
