check engine lamp
Old Dec 27, 2005 | 03:04 AM
easy rider's Avatar
easy rider
Stage II
Default check engine lamp
I have a 1999 FXDWG. I live in the Philippines and we do not have mechanics who can trouble shoot problems on this kind of bike. My light goes on for 4 sec. when I turn on the key and then off for 8 sec. It then comes on and goes off. When I start the bike it comes on and stays on. The bike runs good. I do not have a Scanalyzer. Can anyone help me solve the problem. Thanks John
Old Dec 27, 2005 | 03:09 AM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Default RE: check engine lamp
Check the link below. You should be able to find your problem in there.
https://www.hdforums.com/m_66685/tm.htm
Also, welcome to the forum. You picked a great place to look for information. It's a little slow tonight but you will get some more responses over the next 24 hours.
[sm=biker2.gif]
Old Dec 27, 2005 | 08:21 AM
Sooee's Avatar
Sooee
Welcome from New Zealand
Old Dec 27, 2005 | 08:37 AM
streetglide#1's Avatar
streetglide#1
Welcome to the forum from Florida!
Old Dec 27, 2005 | 09:38 AM
liam51's Avatar
liam51
Howdy John!!!
Welcome to the Forum from Snowy [X(] Downeast Maine.
Old Dec 27, 2005 | 09:44 AM
HDF Tech's Avatar
HDF Tech
This proceedure may also bring up current fault codes https://www.hdforums.com/m_64805/tm.htm
The light on indicates that you have a current fault logged.
Old Dec 27, 2005 | 11:56 AM
John TN's Avatar
John TN
Check the code, if I remember correctly the code will clear after 50 starts, is that correct TC?
Old Dec 27, 2005 | 12:52 PM
HDF Tech's Avatar
HDF Tech
It will clear John as long as it is not still a present trouble. They have to be a start and run of at least 30 seconds too.
Alan Reid
Mar 16, 2019 07:25 PM
kipnowski
Feb 15, 2015 02:35 PM
smashten
Welcome Area Only
21
Jul 27, 2012 10:23 AM
JayPap
Welcome Area Only
24
Jul 16, 2007 08:23 AM
sportbagger
Welcome Area Only
15
Oct 7, 2005 07:12 PM
