Tmax SmartLink Software
Old Nov 28, 2007 | 09:55 PM
HogGlider's Avatar
HogGlider
Default Tmax SmartLink Software
Hey folks, just trying to download the SMLIV Zippers Advanced/End User 2007.0.10 FULL VERSION and when it's finished I try to extract the files but I keep getting an error that says no files exist and blah blah blah.
Is anybody else having this issue from the website?
Old Nov 30, 2007 | 05:52 PM
wallyn's Avatar
wallyn
Default RE: Tmax SmartLink Software
Looks like they have some bandwidth issues.
It is a 70mb file and it really slowed down at about 50%. You might try late at night and see if you are more successful. It might slow down to the point where your system times out.I quit at about 52%, so i don't know if there is some fatal error later in the download.
Old Nov 30, 2007 | 06:33 PM
HogGlider's Avatar
HogGlider
ORIGINAL: wallyn
Well, here is the thing. I was able to completely download the file, even right clicked the folder and viewed properties and I get this for the size of the file:
70.6 MB (74,096,640 bytes)
So it must have downloaded it completely, but it says the file is corrupted?
Old Nov 30, 2007 | 07:53 PM
jferna's Avatar
jferna
I just downloaded it and opened it up and I tried as many functions I could look at with no problems, short of linking it up with my motorcycle.
WHen you opened up the folder, Did you open up the setup.exe file? There are two icons named "setup" One is setup.exe and the other is setup.ini. You can point at them, right click and read the properties and it will tell you which one it is. You want to run the setup.exe. Just follow the prompts and you're on your way!
If that doesn't work, try downloading it again. Hope this helps! Good luck.
Old Nov 30, 2007 | 09:42 PM
mllkn6's Avatar
mllkn6
Didn't have a problem downloading, I use " Internet Download Manager" to download fie, if something happens it reconnects and picks back up downloading and can download from up to 10 different sites at one time to speed up the download. Opened it up worked fine, like jferna said install with the "setup.exe" file. Hope you get it figured out, I agree with wallyntry late at night might make a difference in the speed as some of the users get off. I did take about 10 minutes for it to download, but I was using my Wireless Network Connection and not the Local Area Connection which would have been faster.
Old Nov 30, 2007 | 09:56 PM
HogGlider's Avatar
HogGlider
Thanks folks, I finally got it to work now. Only took about 6-7 tries! LOL
Old Nov 30, 2007 | 10:04 PM
mllkn6's Avatar
mllkn6
That's great, gad to hear it, now let the fun begin. Hope everything goes well from here on.
Old Nov 30, 2007 | 10:44 PM
HogGlider's Avatar
HogGlider
Sure...get about 3/4 of the way through setup.exe file and I get an ERROR
[sm=headbang.gif] I need a damn beer...or three. I am going to wait until later and try again I suppose
Old Nov 30, 2007 | 10:55 PM
mllkn6's Avatar
mllkn6
HogGlider,
PM me with you email address and I will email you the file, maybe that will work, worth a try. Just trying to help.
mllkn6
Old Dec 1, 2007 | 10:35 AM
jferna's Avatar
jferna
Are you running any versions Norton Antivirus software? Normally that will work for all applications with no problems. Check your MS Windows firewall settings. If its on, turn it off. You are not getting all the files and that's when your ERRORs come up. I know it's frustrating. Stick with it. Wish you luck.
