ENGINE WILL NOT FIRE
Old Jan 6, 2006 | 06:37 PM
atl72nova's Avatar
atl72nova
Stage III
Default ENGINE WILL NOT FIRE
Hey I know this is a prev. post but I have I problem> HELP!!! I was riding just like normal, parked my 2003 Fatboy and tried to start later on. Would not start, Engine turns over but no Fire. Changed Spark plugs, and spark plug wires and the Ignition Coil. Still no start. Any tips or something I'm missing. I even replaced the Battery
Old Jan 6, 2006 | 07:24 PM
Geoseismic's Avatar
Geoseismic
Default RE: ENGINE WILL NOT FIRE
Fuel, air, and spark. I would check for spark first by removing a plug, connecting the wire, holding with a rubber or heavy leather glove, and cranking the engine. If spark is evident, go to fuel. Trouble shooting in this arena varies depending on FI or carb. Air is simple. Check to make sure there are no obstructions in the intake (clean air filter) or the exhaust. If you have fuel, air, and spark, then you have a timing issue. This can be anything from ignition, fuel injection, or valve timing.
Good luck!!!
Old Jan 6, 2006 | 07:43 PM
atl72nova's Avatar
atl72nova
Stage III
Well I checked if I'm getting fuel and air, I'm good on those. I did the spark plug check, and there is no fire from either spark plug. Thats what led me to replace the spark plug wires, coil and battery. also I checked the fuse box, no blown fuses. Could it be the voltage regulator?
Old Jan 7, 2006 | 12:08 PM
Steve On 3's Avatar
Steve On 3
A friend had this same problem. His was due to a faulty kill switch on his right handlebar. Loosen the switch housing and wiggle the wires. The try to start with the switch still hanging free.
Hope this helps
Bubba
Old Jan 7, 2006 | 02:10 PM
fxdxsteve's Avatar
fxdxsteve
maybe the bank angle sensor is loose
Old Jan 7, 2006 | 03:12 PM
taurusjim's Avatar
taurusjim
dont forget the stator, also check the wire plug at the voltage reg. make sure it has not got loose...
Old Jan 9, 2006 | 11:04 PM
fxdxsteve's Avatar
fxdxsteve
maybe you need to turn off the security system
JAMES2
Shovelhead
Oct 25, 2024 04:15 PM
Chango1079
Aug 16, 2019 11:37 PM
Sinistral_leo
Jul 16, 2017 06:12 PM
98glider
Ironhead
11
Jun 23, 2014 08:22 PM
HDF Tech
Engine Mechanical Topics
Jul 3, 2005 12:47 AM
