injector max pulse width?
Old Jan 10, 2008 | 12:20 PM
asuperheat's Avatar
asuperheat
Default injector max pulse width?
Just wondering if anyone knowes what the max pulse width is on h-d 25 degree injectors. I am running about 23 m.s. on mine how close to max is that?
Old Jan 10, 2008 | 12:55 PM
man4mopar's Avatar
man4mopar
Default RE: injector max pulse width?
Are you running a Tmax or a DTT or have some way of checking AFR on the go? Determining the max time a injector can be open is more determined by the engine speed,intake and injector flow rate at a given pulse widththen the injectors ability to stay open length. I am not sure how long the injector can be open before a over heat/failure but I am sure you are not near it. Question is more if the pulse width is withen intake engine speed parameters. And I am sure you are fine. This can be checked easy enough by AFR readings in load ranges you ride in.
Old Jan 10, 2008 | 02:12 PM
asuperheat's Avatar
asuperheat
I am using a sert with a head quarters pro tuner on my new 113" build and I was not sure and a little concerned if the stock injectors could support it. The build I am told should produce in the area of 120hp and 130tq. I have not had it on the dyno yet but plan to do so in the next few weeks. I guess if they are maxed out I should see it in the a/f ratio on the top end.
klemay
Apr 22, 2010 02:21 PM
TickTock
Jan 7, 2008 07:28 AM
quint
Jan 21, 2007 06:18 PM
Kahuna
Sep 25, 2006 09:19 PM
BigGeorge
Mar 25, 2006 01:50 AM
