FXST 2000 DTCs
Old Jan 22, 2008 | 10:51 AM
hernan's Avatar
hernan
Default FXST 2000 DTCs
Does anyone knows the meaning of this numbers?
The bike is not working well and is showing this list of codes:
d01Clr
d02Set
d03Clr
d04Clr
d05Clr
d06Clr
d07Clr
d08Set
d09Clr
It's a FXST 2000 carbureted.
Thanks!!!
Hernan
Old Jun 10, 2017 | 11:51 AM
bigspyke's Avatar
bigspyke
1st Gear
Hi , did you ever find out what the code d02set was that you were asking about ! , I have this code showing on my 2000HD night train and the bike is misfiring , I know this was posted some time ago so no worries if no reply ,
cheers
BIGSPYKE
Old Jun 15, 2017 | 07:51 AM
BobO73's Avatar
BobO73
d02Set" Speed sensor power output shorted high or open - Means speeds sensor needs to be cleaned, got a loose wire or connection or other upstream electrical cause (voltage reg). My 99 is throwing it now and I've lost speedo and turn signal cancel. New one on order since I've already checked out the possible causes.
dbrow6272
May 5, 2017 12:04 PM
Henry Colf
Jul 30, 2016 09:14 AM
Superj
Apr 17, 2015 09:54 AM
runningbearau
Jul 12, 2013 02:47 AM
mulch63
Jul 3, 2007 12:56 PM
