Right turn signal problems
Old Feb 8, 2008 | 07:59 AM
Ridinglow's Avatar
Ridinglow
Default Right turn signal problems
Bike just purchased used, so don't know history. It's a 99 low rider. Problem is, when the key is first turned ontoeither theacc or ignition position the right turn signal light frt and back comes on in a very dim mode without blinking for about 15 seconds. It then will go out after getting a little dimmer and flickeringa bit. If I operate the turn signals, either right or left they work fine.
It is almost like the turn signal module is leaking outa littlepower to that side,but not enough to blink. Or, the right turn signal switch is defective andleaking a low voltage signal to themodule, which the module doesn't know how to read, thus it sends out a low voltage to that side.
Is it possible, because the bike has not been moved, the distance mode in the module is messing up the signal to that side? I can't run it as we have snow and ice. I guess I could run it on the jack long enough to activate the cancel function in the module.
Will disconnecting the battery clear the module any better than turning off the key?
Anyone experience anything like this?
Old Feb 8, 2008 | 08:32 PM
Ridinglow's Avatar
Ridinglow
Default RE: Right turn signal problems
Can the turn signal module be bench tested?
Big Dave
EVO
Jul 10, 2015 11:04 AM
phillyrube
Nov 13, 2014 03:42 PM
JR-Boston
Jul 18, 2012 04:23 PM
larsfum
EVO
Jan 12, 2011 11:02 AM
robkei
Jul 5, 2010 08:21 PM
