ENGINE DIES AFTER A FEW SECONDS
Old Feb 22, 2008 | 10:07 PM
dwjones125's Avatar
dwjones125
Stage II
Default ENGINE DIES AFTER A FEW SECONDS
I got my 99 E-Glide out last weekend after it had been parked for about 6 weeks. I fired up rode down to street and back, loaded up my daughter and made it about three blocks and the engine died just as though I had turned off the switch. After checking to see if I had spark, I turned off the ignition, turned it back on and the engine started. It would been for a few seconds and then die. The only way to restart it would be to turn the ignition switch off and then on again.
I finally limped back home and found I could jiggle the switch a little and get it to start. Well today I bought a new switch $113. Installed it and everthing seemed great. Feeling proud of myself for my great diagnostic skills, off I went. This time I made it about 4 blocks and then repeated the same scene as last weekend. I can toggle switch and restart it. But it dies within seconds. It seems to die as soon as theENGINE light goes out. The lights and accesories do not go off. Just the ignition.
ANY IDEAS? PLEASE HELP, I AM SURE WANTING TO GO ON A 300 MILE TOUR TOMMOROW!
99 ELECTRA GLIDE, CARB,SCREAMING EAGLE BIG BORE KIT, SCREAMING EAGLE IGNITION MODULE
Old Feb 23, 2008 | 07:58 PM
dwjones125's Avatar
dwjones125
Stage II
Default RE: Engines dies after warm up HELP
I got it fixed. It was the bank angle sensor. It's function is to kill the ignition if you lay the bike over. It is located under the left side panel. I found that you can unplug it and it will bypass. Anyway I un plugged it, rode my bike 20 mi to HD shop with check engine light on. There I bought a new one $59 installed it and rode home. Hope this helps someone else.
Old Feb 24, 2008 | 04:32 PM
gunnert's Avatar
gunnert
There was a recall on the bank angle sensor from 1999. I have a friend that had his replaced by the dealer 5-6 years ago.
Old Aug 2, 2009 | 05:15 PM
dan05's Avatar
dan05
Stage III
thanks yoall for help disconected bankangle sencer wire went for a putt same thing bike died after 10 min or so let it rest awhile started up happend 2 more times but made it home back to square 1 maybe the ecm probobley ill need to go to the stealer and pay the piper thanks again dan05
Old Aug 2, 2009 | 05:25 PM
Tuco069's Avatar
Tuco069
Hey guys, does it matter if it was a carb or fuel injected model? Do they both have the same sensor?
hotrod1340
Electrical/Lighting/Alarm
Nov 11, 2016 07:42 PM
tmitchellof PG
Sep 5, 2011 01:07 PM
Drac 1
Aug 2, 2009 10:29 PM
SLP24
Jul 26, 2009 11:59 AM
XLR8R
Mar 14, 2006 10:26 AM
