Engine Light
Old Jul 31, 2009 | 01:22 PM
Drac 1's Avatar
Drac 1
Default Engine Light
Maybe this was asked before, I couldn't find it so I will risk being called names and ask again..The red ENGINE light came on in the middle of my ride today..Anything I can do to find out what caused this?
Old Jul 31, 2009 | 02:41 PM
paguy's Avatar
paguy
press and hold odometer rest button
turn ignition sw. to ignition (make sure kill switch is in run position)
"diag" appears in odometer window
press and release reset switch
PSStb appears
P should be flashing
press reset switch for more than 5 seconds
code is displayed (or none if no codes present)
press and release switch again to see if more codes are present.
if no more codes present "end" will appear
to clear DST's press an hold reset for more than 5 seconds
to exit without clearing, press and release the reset switch, turn off ignition
once you have the code, post it back up here, anyone with an electrical manual can look it up.
__________________
Old Jul 31, 2009 | 09:23 PM
gunner11's Avatar
gunner11
I had the same thing up here in Sturgis, they checked for two days and finally tracked it to a broken wire in the wiring bundle on the frame between gas tank and fairing. Mighr want to check there.
Old Aug 2, 2009 | 06:51 PM
Drac 1's Avatar
Drac 1
Thanks for the response..Something to do on my next day off...
Old Aug 2, 2009 | 10:29 PM
baucom1's Avatar
baucom1
I've got an 08 Ultra and the check engine light has come on twice. Each time it came on my cruise control would not work. Both times it was a wire in the cruise control switch housing.
Doug
hotrod1340
Electrical/Lighting/Alarm
Nov 11, 2016 07:42 PM
risdo
Sep 29, 2013 09:15 AM
IndyClassic
Dec 28, 2008 08:38 AM
anubisss
Feb 12, 2007 06:14 PM
reddog06
11
Jul 25, 2006 03:07 PM
