Initializing Tmax
Old Feb 29, 2008 | 07:59 AM
harleykris's Avatar
harleykris
Default Initializing Tmax
When changing maps on the thundermax, do I need to go thru the ritual of starting the bike for ten seconds twice, then letting it warm up again each time I make a change? The instructions are a PIA to get around in. I can't find a map that's close to my set up so I'm having to experiment with different one's, just like I had to do with the PCIII. I did a search and I'm finding that a lot of folks are making adjustments to the Tmax after installation. This is what I was hoping to avoid and why I changed from the PCIII, but it seems that's not quite the case. I'm giving this thing one more try and if I'm not satisfied I guess I'll go back to the PCIII or maybe try something else.
Old Feb 29, 2008 | 04:43 PM
sbbrown's Avatar
sbbrown
Default RE: Initializing Tmax
Give Zippers a call, they will tell you the closest map to your configuration. And yes you do have to initialize after changing maps
Old Mar 2, 2008 | 05:39 PM
fxrp's Avatar
fxrp
Post your setup and we can help.
Put simplythe most important choice is throttle body/injectors, after that displacement. Exhaust, cams,etc will be easily adjusted for. The wide band w/auto tune is much more tolerant than the open loop PCIII.
Old Mar 4, 2008 | 03:16 PM
fxrp's Avatar
fxrp
[sm=WTFsgign.gif] Askingquestion or just making a comment?
128auto
Aug 19, 2008 01:11 PM
salty01
May 30, 2008 03:24 PM
jeff194
May 26, 2008 08:33 PM
T_Rob666
Jun 14, 2007 03:46 PM
MCSarge
Mar 16, 2007 12:32 AM
