Battery Tender Question
Old Jan 30, 2006 | 11:53 AM
nasumi2002's Avatar
nasumi2002
1st Gear
Default Battery Tender Question
One quick questions, do I need to remove the red (positive) cables before I hook up the battery tender? Or can I leave it attached?
Old Jan 30, 2006 | 12:15 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Default RE: Battery Tender Question
Always remove the ground (negative) cable from your battery when you are working on your bike. Then hook up your battery tender installing the negative cable last. When charging the bike you don't need to unhook anything, just plug in the harness to the tender.
Old Jan 30, 2006 | 12:43 PM
HDF Tech's Avatar
HDF Tech
Terry told you right, that guy knows his stuff. The reason for the neg. cable is that there is less chance of hitting the wrench on the frame (ground) doing it this way to avoid a spark and possible damage to the battery , yourself, or the chanrging system. Batteries can emit hydrogen gas when charging which is rather explosive in itself given a source of ignition.
Old Jan 30, 2006 | 01:48 PM
Terry TK's Avatar
Terry TK
ORIGINAL: TCSTD
Aw Shucks Bill, now I'm blushing.
HOG WRANGLER
May 8, 2010 03:17 PM
JamesDean
Dec 29, 2008 07:20 AM
Handycam
Nov 20, 2008 03:25 PM
Hidalgo
Jan 6, 2008 12:25 AM
docker
VRSC Models
Aug 7, 2006 02:33 AM
