Hey, Terry
Old Feb 4, 2006 | 09:22 PM
Jezcruzen's Avatar
Jezcruzen
Default Hey, Terry
I removed the SEII slip-ons and the stock head pipes last weekend and replaced them with a D&D Fat Cat (2 into 1) exhaust system.
The bike has been performing relatively well since the switch, with some popping during decel. (I noticed more popping yesterday during a ride, but it often popped with the SEIIs as well.)
Today I removed the heat shields in order to make more room for me to re-torque the exhaust flange nuts just in case they loosened a little since the install last week. I noticed that the head pipes had blued up near the exhaust ports. Is that normal, or is it due to the bike running lean?
I was ready to re-map the ECM today, but after attaching the SERT interface cables, I discovered that I couldn't attach the cable to my laptop due to the fact there was no serial port (male) available. (I'll have to buy an adaptor and use one of the laptop's USB ports)
I plan on having the bike dyno-tuned in March after the local dealer dyno techs complete their updated dyno training scheduled for this month.
Old Feb 4, 2006 | 09:29 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Default RE: Hey, Terry
Les,
It's not uncommon for the head pipes to blue near the heads. You probably are running lean though with the blueing and the decel pop. Once you get your adaptor for your computer load a map that will make it run rich until you can have it dyno'd. You can adjust your map that you are currently runnng for a slight richer mixture too if you already have a SERT map loaded.
Old Feb 5, 2006 | 10:24 PM
Jezcruzen's Avatar
Jezcruzen
Yeah, I'm going to do just that, Terry, once I find a PDA adaptor so I can use this IBM laptop.
Thanks for you comments.
Les
Old Feb 6, 2006 | 12:19 AM
Terry TK's Avatar
Terry TK
No problem Les. Good luck with your tune.
Divinitus
May 1, 2012 09:41 AM
ultravista
Exhaust System Topics
Sep 24, 2009 11:30 PM
jdw1951
Jun 7, 2009 07:12 AM
hAkron
Aug 27, 2007 08:32 PM
purple haze
Mar 18, 2007 03:19 AM
