Problem Loading
Old Mar 26, 2008 | 11:26 AM
Herr Monk's Avatar
Herr Monk
Default Problem Loading
SERT map load cut out halfway through load, now ECM won't even power-up... Any ideas?
Old Mar 26, 2008 | 12:26 PM
VTwinJaxFL's Avatar
VTwinJaxFL
Default RE: Problem Loading
ask this question on www.vrodforums.com and you will get a quick answer
Old Mar 26, 2008 | 12:51 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
ORIGINAL: Herr Monk
What do you mean by "power up"? DId you get an error message?
Old Mar 26, 2008 | 01:18 PM
Doc 1's Avatar
Doc 1
Go to the help section in the tool bar of the SERT under 'program failure' and follow the procedures to recover the ECM. If this doesn't help take the ECM out and take it to a dealer, they can put it on a donor VRod and give birth to the ECM with the Digital Tec, or you can take your bike in then a donor isn't needed.
Old Mar 26, 2008 | 03:25 PM
Herr Monk's Avatar
Herr Monk
Fixed it! Thanks all!
tanglefootrgu
Mar 23, 2009 08:51 PM
skeyediver
Sep 23, 2008 06:33 AM
whitz
May 10, 2008 12:14 PM
FLSTF
Feb 7, 2008 04:48 PM
wb0zrd
Jan 5, 2008 09:13 PM
