PClll/computer/bike
Old Apr 2, 2008 | 02:41 PM
60wt's Avatar
60wt
Default PClll/computer/bike
I thought i read a post recently where some one had already installed a PClll with a map, rode the bike and decided to change the map by removing the PC lll from the bike ,hook it up to his computer with the 9 volt, change the map and return it back to the bike plug it back in and ride it...I know that the first time you have to set the throttle position when first installed to make it all work while on the bike. in other words the PClll has to be connected to the bike AND the computer to do that.. So I guess its ok to remap the commander on your computer WITHOUT resetting the throttle position..???...Whaddya think about that..
Old Apr 2, 2008 | 05:07 PM
Doc 1's Avatar
Doc 1
Default RE: PClll/computer/bike
Once the PCIII has had the TP set for that bike it should be ok....but....like anything else with electronics there is a chance it will have to be done again. It's easy to find out....when you hook it bac kup power it up and look at the TP while idling...is it '0' or not.
Old Apr 2, 2008 | 10:41 PM
iclick's Avatar
iclick
ORIGINAL: 60wt
I agree with Doc that TP settings should not change when the PCIII is removed from the bike. BTW, you don't need to remove the PCIII to do map changes. Just attach the 9V adapter and you're set. Of course if you can't get the computer close enough to bike you'll need to remove it.
Old Apr 3, 2008 | 07:11 AM
VTwinJaxFL's Avatar
VTwinJaxFL
I am guessing you want to do this because you can reach the bike with your PC, and don't have a notebook computer. I have adjusted the map on my PC III USB and did not ever have to touch the throttle position.
Old Apr 3, 2008 | 02:53 PM
60wt's Avatar
60wt
nope , no laptop...did the initial set up in my brother in laws livingroom ,hard getting a road king through the front door, dont want to do that again, much easier to remove the PC if that will work ...thanks for the replys...
Old Apr 4, 2008 | 02:38 PM
60wt's Avatar
60wt
contacted power commander, they said throttle position will remain the same... thats the reason for the 9 volt battery
epd612
Nov 21, 2010 12:21 AM
salty01
May 30, 2008 03:24 PM
Spanish Flyer
Sep 7, 2007 07:49 PM
MCSarge
Mar 13, 2007 08:37 PM
barrygreen
Dec 14, 2005 03:44 PM
