Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Short story - picked up a rolling chassis with and EVO motor - owner did not know exact year of motor but it is between 91 -96.
-Ignition : Crane Hi4
- Coil : Dual fire
- Wires - Crane Fireball for EVO motors
Bike fires up but no rear cylinder ...nothing nada
- Good spark
-Changed wires
- Changed coils
- Changed plugs
- Changed Hi 4
Checked timing numerous times, according to Crane inst if I find the timing mark and turn the HI4 it should go out at TDC....neither of the 2 Hi4 I have is working according to the inst.
Damn! You got me, you have fire, gas, compression? If the front fires youshouldn't be180* out on the timing with dual fire. Don't know where to go from there. Hope someone can come up with an answer! Good Luck!
