Error Code 61122
Old Jun 10, 2008 | 08:19 PM
DGlide04's Avatar
DGlide04
Default Error Code 61122
I posted this up in the Dyna section also, but though there might be more electrical experts lurking around here.
I've searched for trouble codes, I know some have been posted but I can't seem to find them when you need them.&nbsp\\; Short story, coming home last weekend, the red security system key light came on, but a check revealed no error codes.&nbsp\\; Everything worked okay yesterday, no problems.&nbsp\\; I go out tonight and my right turn signal won't work.&nbsp\\; The running lamp (stock bullets) are on front and back, but no signal.&nbsp\\; When the ignition is turned on, the left signal blinks 6 times and goes off.&nbsp\\; Left side works fine, no right signal.
A check of the error codes shows the following:&nbsp\\; S for the Ignition Control Module, indicates error 61122.&nbsp\\; Can anyone tell me what the error code is?&nbsp\\; I can't find it listed anywhere.]]
The PIA is that everything was working good yesterday and when I checked the bike out tonight getting ready to go to work tomorrow, I get the codes thrown at me.
The bike is a 2004 FXD, stock lights and wiring, starts and runs fine, just no R signal.
Thanks.
Old Jun 11, 2008 | 06:33 PM
littlet's Avatar
littlet
Default RE: Error Code 61122
it has something to do with your right bulb not working fix that and the code should go away.
Nokkon Wud
Feb 26, 2018 10:18 AM
darterd
Dec 15, 2017 10:45 PM
SiggerTX
Oct 13, 2017 07:30 AM
WHITEHOT5055
Sep 16, 2015 08:44 AM
DGlide04
Sep 22, 2010 08:25 PM
