Turn signal flashing code?
Old Oct 12, 2017 | 09:21 PM
SiggerTX's Avatar
SiggerTX
Default Turn signal flashing code?
Something odd today while working on the bike (06 FLHT). I had the right blinker on and I turned the ignition switch off. Right blinker then flashed 4 times slow, 7 times fast. Never seen that before, tried it with the left blinker on, same right signal flashes. Tried it with no signal on, no flashes. Checked the diagnostic codes, P0373 which I knew about (picking up new sensor saturday). Cleared the code and tried it again with the same odd blinking. What is my bike trying to tell me???
Old Oct 13, 2017 | 07:28 AM
ohioflhs's Avatar
ohioflhs
Sounds similar to what mine did when it had some codes stored. When I turned on my turn signals, they would blink normally about 3 or 4 flashes and then would flash quickly. I cleared the codes and it went away. Fixed the cause of the codes and it hasn't happened again for years now. 2008 FLHTC.
Old Oct 13, 2017 | 07:30 AM
Iceman24's Avatar
Iceman24
You need a "bike whisperer" to relay what it's trying to tell you...
JK, something amiss and stored in diagnostics & hopefully she clears when you install new sensor. If not, re-check codes...
Bktlist
Jul 12, 2016 09:50 AM
ddg22
Electrical/Lighting/Alarm
Jan 1, 2016 10:25 AM
markkoby
Nov 5, 2012 11:13 PM
Trikerjon
Apr 4, 2011 11:56 AM
dawg
Oct 29, 2007 11:03 AM
