charging problems?
Old Jun 13, 2008 | 05:40 PM
06 harley's Avatar
06 harley
Default charging problems?
i replaced the battery on my 06 dyna super glide custom due to it being bad. after that i check the voltage at the battery with the engine running(now that it will start). i am getting @12.6 volts at idle and if i rev it up i get about 12.8-9 volts. at times the check engine light will come on along with the battery light. any ideas?BRIAN
Old Jun 13, 2008 | 06:32 PM
Doc 1's Avatar
Doc 1
Default RE: charging problems?
Either a magnet came loose in the Rotor or the regulator is bad or the sator needs replaced...
Old Jun 13, 2008 | 06:34 PM
littlet's Avatar
littlet
check your ac volts at the stator plug... should be 20 vac per 1000 rpms! if not you have a bad stator! if this is true you may also have a alternator that seperated from the compesator spring shell by all the bolts backing out and tearing up the stator!
Old Jun 13, 2008 | 07:17 PM
06 harley's Avatar
06 harley
where is the stator connector? i feel stupid asking these questions as i am actually an auto mechanic! BRIAN
Old Jun 13, 2008 | 11:15 PM
rok312's Avatar
rok312
ORIGINAL: 06 harley
I recently had the same problem - ended up being the voltage regulator going kaput.
Old Jun 14, 2008 | 01:02 PM
littlet's Avatar
littlet
stator connector is under the voltage regulator, remove the two 1/4 20 3/16 allen head screws to remove and expose the plugs.
Old Jun 14, 2008 | 03:35 PM
06 harley's Avatar
06 harley
there are 3 or 4 connectors there! which one is it?-BRIAN
Old Jun 14, 2008 | 06:36 PM
06 harley's Avatar
06 harley
is it the 3 pin connector that goes into the left side of the engine? if so what pins do i check???BRIAN
Old Jun 17, 2008 | 07:59 PM
06 harley's Avatar
06 harley
anyone?????????????? i need to get this thing fixed! i wanna go ridin'!-BRIAN
Old Jun 18, 2008 | 06:14 PM
littlet's Avatar
littlet
service manuals do wonders!!!! yes it is the 3 prong plug check each wire with&nbsp\\;the other 2&nbsp\\;opposing phases!
