cam timing sensor wire color code
Old Jul 2, 2008 | 09:35 PM
hegerts's Avatar
hegerts
Stage I
Default cam timing sensor wire color code
I&nbsp\\; have a stock hd evo cam sensor&nbsp\\; 32448-95a&nbsp\\; with BLK/wht and GRN/wht and RD/wht in a custom application and would like to know what wire needs to go to what?
thanks
Old Jul 3, 2008 | 08:56 AM
Javieret's Avatar
Javieret
Default RE: cam timing sensor wire color code
Here you have the 99 FXST electrical diagram. I think this is what you need.
Regards,
Javi
Old Jul 3, 2008 | 09:01 AM
Javieret's Avatar
Javieret
I think that the attachment don't works. I try again...
[IMG]local://upfiles/17793/A0D5E20C13E04BA0AE9F7B2F4CA5F641.jpg[/IMG]
Old Jul 3, 2008 | 09:27 AM
im's Avatar
im
my 1998 road king classic fuel inj. uses that same # part...
book has a test for green w/ white tracer and black w / white tracer wire being touched together with (switch to ignition) for VEHICLE ATTITUDE TEST..(bike falling on side) should read 5 volts dc in verticle position and about 7 to 9 volts in horizontal after about 2 seconds..
the black wire w/ white tracer refers to&nbsp\\; reading of ZERO on digital voltage meter when&nbsp\\; one end is attached to it and ground.
Old Oct 18, 2008 | 07:23 PM
dakerstrom's Avatar
dakerstrom
Stage I
Default cam position sensor interchange
Does anyone know if the cam position sensors 32404-90, and 32404-96 are interchangable if the connectors are cut off and the appropriate wires are spliced together? The 96 costs $170, while the 90 costs $53
Scottyxbones
EVO
Aug 23, 2018 07:21 PM
jamespedro28
Jan 15, 2016 03:47 AM
Dgaroutte
EVO
13
Jul 4, 2014 09:24 AM
EVELdave
Electrical/Lighting/Alarm
14
Jun 7, 2013 09:10 PM
jsbridgew
EVO
Mar 28, 2011 08:05 PM
