Need DTC Code help
Old Jul 6, 2008 | 09:39 PM
Goaler34's Avatar
Goaler34
Stage II
Default Need DTC Code help
I have a 06 FLSTCI.&nbsp\\;
It is throwing the following 3 codes:
P0113 IAT Sensor Voltage Open/High EFI
P0118 ET Sensor Voltage Open/High EFI
P0123 TP Sensor High EFI
Anyone have any ideas or suggestions?
I originally thought it was the voltage Regulator so I swapped that out, but that doesn't seem to have been it.
Old Jul 7, 2008 | 12:20 AM
Doc 1's Avatar
Doc 1
Default RE: Need DTC Code help
It's telling you the resistance is high in the wire harnes to these three sensors .All these three sensors are in the same harness and they have been known to be stretched a little tight....I lift the tank and make the wires have a little slack to the sensor connections.&nbsp\\; Tis ususally works 95% of the time.
Old Jul 8, 2008 | 05:23 PM
Goaler34's Avatar
Goaler34
Stage II
Slack in the harness doesn't seem to have helped.&nbsp\\; I reset the codes and it's only throwwing p0113 and p0118 now.
&nbsp\\;
I think the throttle code might have been because I had to open the throttle to get it to start.&nbsp\\; I cleared that one and it hasn't come back.&nbsp\\;
The other two, the Air intake and the Engine temp are driving me crazy.
Z
24
Nov 3, 2018 08:49 PM
53 pan
Sep 13, 2012 08:18 AM
devils haircut
Jul 3, 2009 08:41 AM
JefFLH
Apr 27, 2009 12:11 PM
