Problems starting
Old Aug 21, 2008 | 09:34 PM
IN Glide's Avatar
IN Glide
Question Problems starting
I had the ignition switch changed out on my 08 Street Glide due to the fact that when I would rotate it to the accessory area to listen to the radio it would not work. Since the dealer changed it, I have had an occassional issue with the bike not starting. I will turn the switch to start and some of the gauge lights turn on. It appears that the stereo will not turn on. When I turn the bike to run, the fuel pump turns on but when I hit the start button nothing happens. Sometimes I can hear a very faint click near the seat area when I press the start button. Any ideas what it could be. Not sure if it is a short or the new switch the dealer put in is bad. I am sure when I take it to the dealer I will never be able to reproduce the problem.
Thanks in advance.
Old Aug 21, 2008 | 10:22 PM
Shovelhead Bob's Avatar
Shovelhead Bob
One of the 3 wires in the plug could be loose, inside the plug assy.....
It plugs directly into the ignition switch...
SluggoMagoo
May 31, 2018 07:47 AM
jmn1960
Sep 17, 2015 08:02 PM
PHUNX
Jul 19, 2012 10:51 PM
Iron_Rookie
Ironhead
Apr 27, 2012 03:29 PM
chamberlinjohn
Aug 29, 2008 07:56 PM
