wilhelm
Old Aug 27, 2008 | 08:14 PM
WILHELM's Avatar
WILHELM
Stage I
Angry wilhelm
I just bought a 2002 Altra Classic Harley and I would like to know why it shut's down at a low RPM. It runs good on the highway but at low RPM the bike will shut down completely.PLEASE HELP!
Old Aug 27, 2008 | 10:51 PM
LilBudyWizer's Avatar
LilBudyWizer
Is it all the time at low rpm, i.e. do you have trouble starting it? Or is it just after you've been running for awhile on the highway? I'm not sure with an '02 but I assume you have an idle air control valve. If it's all the time then likely the bike has blown oil out the breathers, it got sucked into that passage and over time it has congelled and blocked the passage.
If it's only after long drives then it's likely a loose connection. The ecm starts with the IAC in a known position then counts steps from there. So if the connection is loose some of the steps the ecm told the IAC to make don't get made. So over time if it's losing more opening steps than closing it can end up closing the IAC when it thinks it is partially open. Stopping the bike, turn it off and turning it back on should fix it since the ecm recalibrates it when you turn the ignition off.
If happens all the time then you need to pull the IAC, clean the threads on the pintel and spray some carb cleaner in that passage to clear the gunk out of it. If it's only after riding for awhile then you need to pull the connector off and tighten the female part so it makes a better connection. You might clean it too to make sure you get a good connection.
Now if an '02 doesn't have an IAC then just ignore that I'm pretty certain it has an ecm and if so then it has to control the air flow into the engine. It might actually work the throttle plate directly. Alternatively, even if you have an IAC, you might have a really dirty filter element on the ac. If you don't have a service manual it would be a good idea to get one. It will tell you if you have an IAC, how to identify it, remove it, install it and how to clean the ac. Otherwise take it to a shop and have it repaired.
macnab_sf
Jun 16, 2020 04:23 PM
Renoir1
Sep 7, 2016 08:48 PM
VTL nut
EVO
Apr 29, 2013 03:12 PM
Mcatee2006dyna
Aug 10, 2011 09:04 PM
kehrer34
Aug 12, 2007 12:38 PM
