ECM auto adjust to Stage 1 changes?
Old Sep 1, 2008 | 10:08 PM
fxd2001's Avatar
fxd2001
Default ECM auto adjust to Stage 1 changes?
In the October 2008 American Iron on page 165 it is stated that the 2007 and later ECM units will use information from the exhaust sensors to maintain the proper air to fuel ratio if you change the air cleaner and exhaust. This means no fuel compensator like a Fuel Pak is needed. Can anyone confirm or deny this from experience?
Old Sep 1, 2008 | 11:45 PM
glens's Avatar
glens
Yes. From experience I can confirm they are wrong. Driveability issues rear their ugly heads very quickly, and decisively, if you try to do that.
Their primary purpose for even existing is to make a living selling advertisements and associated products via the articles praising them.
Our O2-sensor-equipped bikes indeed have a form of autotuning. But the way it works is to autotune the programmed-for parts to varying conditions in which they interoperate. Not to autotune for non-programmed-for parts. The effects can actually be the opposite of what is needed in that case.
Don't believe it for a minute. Okay? I'm not trying to sell you one cotton-picking thing.
Old Sep 1, 2008 | 11:54 PM
robzuc97's Avatar
robzuc97
Dealer has to download ECM updates on DataLink for changes. Running it without may cause some EFI sensors to read "wrong" and throw a trouble code.
Old Sep 2, 2008 | 06:23 AM
airfuel's Avatar
airfuel
The 02 sensors are trying to keep the bike at an emissions friendly lean 14.7-15.1 air ratio.
way too lean for a happy motor in my opinion.
Even if they did auto tune, why would you want it to tune to a lean condition?
These air cooled motors are not built to run lean, they like gas!
Listen to Glens, he knows his stuff.
Old Sep 2, 2008 | 08:49 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Sorry, but not true. You need at least the dealer stage 1 download to be sure you don't do any engine damage due to an over lean condition.
Old Sep 2, 2008 | 11:50 AM
CR's Avatar
CR
For my cvo 2008 a stage I download does not even exist, and I understood that is the case with other 08 models too (not sure however).
Old Sep 2, 2008 | 01:33 PM
LilBudyWizer's Avatar
LilBudyWizer
176MV003 says CVO 1800 SE A/C & Race Exhaust
Old Sep 2, 2008 | 10:55 PM
CR's Avatar
CR
€Lil Thanks for the tip. However 176MV003 is for Cal ID Big Twin -2008 while there is a separate column for 2008 Touring models where it says n.a.. I will contact HD about it.
Old Sep 3, 2008 | 08:29 AM
tpolstc's Avatar
tpolstc
Oxygen sensors are designed to monitor the amount of unburned fuel to air ratio based on heat generated by the exhaust system.True they self tune the AFR but these set ups are primative to the technology of a car or truck..Years past the system was simple, one wire that created an AC signal and the sensor was grounded to the manifold when installed.These set ups are basically the same..they determine the AFR based on heat generated(the hotter the leaner) and constantly change from rich to lean in milliseconds..way to fast to see unless using an osilliscope to watch the wave form..BUT they all need a reference point to go by..When the engine just sits and idles the exhaust cools off somewhat an puts the O2 sensor in what is called OPEN LOOP..at this point the engine is running from a program only(what is installed into the ecm software)when it gets hot enough it switches to CLOSED LOOP this is where self tunning comes in..now the engine is running "ON ITS OWN"...BUT IT IS LIMITED AS TO HOW FAR IT VARIES FROM 14.7:1 which is where they set these bikes to run.A tunner changes the programs and can change the refernce to 13.8:1 or what ever your needs are..Now the engine is always tring to obtain the new setting(s)..Heated Oxygen Sensors are always in closed loop after an initial heat up process some where around 30-60 seconds and stays in closed loop all the time..much better technology, wider AFR's better performance,fuel mileage.I think as the years creep up on us they will be changing to Heated Oxygen Sensors for better performance all around which is why you can purchase the tunners with wide band o2 sensors..
Old Sep 3, 2008 | 09:53 AM
comaman2's Avatar
comaman2
o2 senors, which I like to call engine performance inhibitors.All they are is harley davidsons answer to federal epa regulations and they are what are making the new bikes overheat,Of course this is just my opinion but its just has good an answer that you would most likely get at the stealer,I got rid of my sensors on my 06 bob and have beenhappy ever since
