The 2009 RK fuel pump doesn't turn on
Old Dec 29, 2008 | 08:51 PM
rrcenger's Avatar
rrcenger
Default The 2009 RK fuel pump doesn't turn on
I have some minor issues with my 2009 RK. I attached a battery tender and the negative connection was loose. When I turned on the main switch the fuel pump sputtered but the starter motor would not engage.
Finally, I found the loose harness connection (to the negative battery terminal) and tightened it. I turned on the main switch and the little bike turned right over and rumbled until I turned it off.
I went out to turn it on again but now the fuel pump won't turn on even though the starter motor will. What did I screw up? Is it a fuse or did I blow the fuel pump somehow?
Thanks.
Old Dec 30, 2008 | 07:38 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Check the fuel pump fuse... I'ts clearly marked on your fuse panel cover....
Old Dec 31, 2008 | 10:38 AM
rrcenger's Avatar
rrcenger
Default I check them this morning...
Thanks...I check all the fuses and all seem OK. Could I have blown one of the main relays (you know, the little black box guys)? Sorry to be so technical. How do I check those, or do I just order them in?
Thanks...
rrce
PS. I hate it when I know my bike isn't working--even when its snowing...
06rkblue
May 21, 2015 04:38 PM
TheDarkKnight
Feb 3, 2013 02:07 PM
ramu3527
Aug 13, 2012 08:41 PM
rlchristensenmd
Apr 17, 2012 11:32 AM
EDdoc521
Jan 29, 2011 06:55 PM
