Voltage Drops
Old Feb 26, 2009 | 03:24 PM
matthewmarek's Avatar
matthewmarek
Stage IV
Default Voltage Drops
I have a 1992 Ultraclassic - When useing turn signal my voltage guage on the dash drops to bottom and then jumps with the fashing of the signal. I have a new self-canceling module installed with no change - tracked and cleaned all ground connections. Any suggestions?
Old Feb 26, 2009 | 03:36 PM
stroker1948's Avatar
stroker1948
Yes, don't trust the guage. I have seen several of that vintage and before with the same issues. You can get a digital volt meter to check the voltage.
Stroker
Old Feb 27, 2009 | 11:38 AM
matthewmarek
Stage IV
I have tested with a meter and it shows the same fluctuation in voltage. I am at a loss to explain it.
Old Feb 27, 2009 | 11:39 AM
BigGdawg's Avatar
BigGdawg
May need a new battery.
Old Feb 27, 2009 | 01:14 PM
UltraNutZ's Avatar
UltraNutZ
sounds like a ground problem. check your main 3 ground wires...
1. at battery and frame connections
2. at starter solenoid
3. front cyclinder head to frame
Old Feb 27, 2009 | 04:29 PM
matthewmarek
Stage IV
Thanks for the responses - I will check grounds where suggested and let you all know the results. Why does electricty hate me so much? My house likes to test my electical abilities too!
Old Feb 27, 2009 | 05:20 PM
bagga's Avatar
bagga
my 85 does the same thing. it's been doing it since it was new. it has never been a problem. if it ain't broke, don't fix it.
Old Feb 27, 2009 | 05:37 PM
sqdealgeorge's Avatar
sqdealgeorge
Just make sure your bike is charging If you want to know how to check just ask the forum
Goose_NC
Electrical/Lighting/Alarm
19
Aug 13, 2018 03:24 AM
BezerkoBob
2014-2024 Touring Models
Jun 28, 2017 07:41 AM
Seabeeron
Sep 6, 2013 10:38 PM
TOTMPL
Sep 21, 2010 06:58 AM
Inferno00
Jul 27, 2006 09:04 PM
