charging system
Old Apr 22, 2009 | 10:03 PM
93 fatboy's Avatar
93 fatboy
Default charging system
I got a new battery, new regulator and new stator, my volt meter reads 18v across the battery while its running. I'm concerned that this is too high. Can anyone give me conformation on this issue?
Old Apr 28, 2009 | 01:35 PM
jmetro's Avatar
jmetro
that is too high. should be 14.5-15 vdc max.
Old Apr 28, 2009 | 01:45 PM
tombeving's Avatar
tombeving
I replaced all three on a 2000 Road King and my volt meter showed 14.5 - 15 running. Pull the plug between the stator and the voltage regulator start the bike and check your voltage there. At @ 2000 rpms it should read about 42 volts. If your getting 42 volts then the regulator is probably the problem.
Old Apr 28, 2009 | 03:02 PM
Hal64hd's Avatar
Hal64hd
I had the same problem before, Thought it was the regulator. After replacing the regulator it was still doing the same thing, turns out it was a defective stator
Old Apr 28, 2009 | 05:16 PM
rjmac53's Avatar
rjmac53
let us know...
96RK
Dec 18, 2011 06:24 PM
flagshipjoe
Nov 24, 2011 01:09 PM
Havanacigar
Jun 2, 2011 08:40 PM
bigcity2010
Mar 31, 2010 07:06 PM
byronrub
Jun 10, 2009 12:07 PM
