Testing the charging system?
Old Jun 2, 2011 | 08:59 AM
Havanacigar's Avatar
Havanacigar
Default Testing the charging system?
Hey all... I have a 2000 FX that I just put a battery in last week, bike ran great up until yesterday, wont start, charged it up and its good to go...so my question is How can i check my stator/alternator? and is it possible to check the rectifier? How do you do it? Guys...I'm lost when it comes to electrical problems, so any advice would be appreatiated, Thanks, Jim
Old Jun 2, 2011 | 09:08 AM
Dallas 13's Avatar
Dallas 13
Simplest test is to check battery voltage with a meter. Should be 12-12.5 volts sitting; with the motor running it should be at least 14 volts; if not, I would suspect regulator first. The input to the regulator is AC voltage - not sure of spec for your bike, but if nothing there I would suspect stator.
Old Jun 2, 2011 | 09:45 AM
Havanacigar
Thanks for the reply Dallas, do you know of a way to check the regulator?
Old Jun 2, 2011 | 08:40 PM
harleytuner's Avatar
harleytuner
Normal testing wold be to check the voltage (DC) at the battery, like siad, it should be around 12 V at idle, ramp up to 14.2 or so at around 2000 RPM's, if not then you would check your stator next. unplug the stator and probe it (AC current) differs on year and model of bike. If you have the AC current check each lead for a short to fround, you can use the continuity funtion of your meter if it has it. If either of these tests fail the stator/rotor is the problem. If they pass then it's the voltage regulator.
asigetic
Aug 20, 2012 06:56 AM
04nightrain
Mar 17, 2011 06:15 PM
byronrub
Jun 10, 2009 12:07 PM
93 fatboy
Apr 28, 2009 05:16 PM
Inferno00
Jul 28, 2006 05:27 PM
