voltage regulator
Old Mar 17, 2011 | 03:12 PM
04nightrain's Avatar
04nightrain
1st Gear
Default voltage regulator
If the stator and the rotor are replaces and the bike is still not charging, what are the chances that its a bad voltage regulator? runs great but just won't charge.
Old Mar 17, 2011 | 06:15 PM
harleytuner's Avatar
harleytuner
It's a safe bet that that's what it is, unless they battery is bad and won't take a charge.. But my question would be did you replace the stator and rotor without testing them or were they bad? Here's my charging system trouble shooting. Check voltage at battery terminals with bike running, if not putting out over 12.8 volts check stator (the stator is AC current, not D.C.) If stator is putting out then it is either your voltage regulator or a bad battery, so at this point I would put a load test on the battery. Since you already replaced the statoryour problem is one of two things (well 3 if you count a bad wire), it's either the regulator or the batter. So load test the battery and go from there.
vicsponjr
Sep 15, 2019 06:24 PM
Miker7
Nov 28, 2018 04:18 PM
dochawken
Sep 1, 2014 07:46 PM
FL-kruzen
Mar 28, 2012 06:46 PM
schlof
Dec 16, 2005 05:35 PM
