RoadGlide Problem
Old May 24, 2009 | 08:16 PM
Redd's Avatar
Redd
Angry RoadGlide Problem
Having a problem with my 00 SERG, and hoping some1 here can help me out. Started out with a loose ground connection at the battery, however not loose enough to really notice, and when I put the charger on it, sparks flew from the neg post. After i tightened the cable up, the bike started fine , however I now have no lights. Figured it was just a fuse, from when it sparked up, and sure enough the fuse was gone. After replacing it, turned on the ignition and the fuse blew again immediately.
Thinking maybe I had a short in 1 of the bulbs or something I started checking, could find nothing so I started eliminating lights. Unplugged power to all rear lites and pulled the fairing off and disconnected headlites. Also popped bulbs outta front signal lites. Tried a new fuse and same thing, blew rite away. Now I'm at a stand still, not sure where to look next. Any ideas or suggestions would be greatly appreciated. Thx in advance...Redd
Old May 24, 2009 | 08:35 PM
Bent Wrench's Avatar
Bent Wrench
You are on the right track, keep diggin".
Pull the tank and look for a pinch, re-test.
Unplug the bars from the harness, re-test.
Inspect all fairing wiring, guages have lights....
Old May 24, 2009 | 09:11 PM
Redd's Avatar
Redd
Thx, I'm still on it! Never thought about the gauge lites tho. Good idea.
ElectraJim
Electrical/Lighting/Alarm
34
Sep 1, 2016 07:58 PM
knights
May 3, 2014 09:27 AM
bakednormals
Jan 19, 2013 09:45 AM
cmdindy
Mar 16, 2011 08:03 PM
maineultraclassic
Jun 3, 2008 07:19 PM
