PC III problems
Old Jun 2, 2009 | 06:05 PM
r0ckie's Avatar
r0ckie
Unhappy PC III problems
I'm trying to use a PC III from my 04 Ultra on my new 07 Ultra. I added the 2 O2 Sensor eliminators and tried 2 new maps - one from Fuelmoto and one from PowerCommander. Also have a Stage 1 breather and V&H slip-ons.
Both cause harder starting and a lot of exhaust pop on decel. And neither improve the bike's performance.
This unit really lit up my 04 Ultra so what am I doing wrong here?
Fuelmoto says the PC III should work just as well as a PC-V and suggested upgrading the firmware in the PC III.
Any suggestions or should I try a different tuner/ECm aotogether?
Frustrated,
r0ckie
Old Jun 2, 2009 | 07:40 PM
Arcane's Avatar
Arcane
The guys at Fuelmoto are generally pretty sharp on Power Commander stuff. If they suggested a firmware update then I would give that a try first.
Old Jun 3, 2009 | 06:46 PM
r0ckie's Avatar
r0ckie
Default PC III problems
How do I do that? I only saw Map downloads at the Power Commander website.
Thanks, R0ckie
Old Jun 5, 2009 | 01:16 AM
Tab's Avatar
Tab
This link should help you out...
http://www.powercommander.com/powerc...downloads.aspx
Old Jun 5, 2009 | 07:23 PM
relxn88's Avatar
relxn88
Frustrated,
r0ckie
When you say your using a Pc111 and not the pcusb, then it won't work. The older PC111 only work up to 2004, due to an ecm change, by Harley, in 2005. You need a pcusb or a retrofitted PCV for the 2007.
Old Jun 17, 2009 | 01:32 AM
OLD 96's Avatar
OLD 96
I just installed a retrofitted PCV from fuelmoto on my 2007 Ultra. Am very happy with it so far. But, I do miss tuning a carb bike.
Old Jun 18, 2009 | 04:46 PM
bobbyclobber's Avatar
bobbyclobber
Stage II
I have a PClll on my 08 heritage and it too was hard starting and had some decel popping eetc. The hard starting was fixed by hitting the start button immediately after turing on the igniton switch vs waiting for the injector light to go off and it now starts right away. As for the decel popping, it disappeared after about 10 to 15 hours of driving. I believe the ecm module adjusts itself somewhat to the fuel air conditions or something like that, but your decel popping should improve with time.
Rickierockit92
Apr 8, 2014 11:53 PM
1sweetglide08
Touring Parts
Oct 29, 2009 05:36 AM
yota
Jul 13, 2009 06:23 PM
pbsdaddy
Jul 4, 2009 06:06 PM
boatcapt
May 7, 2009 08:51 AM
