Interesting Engine Temp Sensor Behavior
Old Dec 1, 2022 | 10:19 PM
devote0805's Avatar
devote0805
Could this also cause my bike to stall while riding? I've been having a problem with my 2002 Harley Sportster 883 where at first it was popping and coughing through the carb then started to back fire then would shut off after. I would wait for a minute or less and all power would come back on. So i bought a new battery for it also ended up buying circuit breaker as well and a new ign. Module and cleaned out my carb. I turned it on ran it for about 30 mins it ran great no more back fire coughing or anything. Then I turned it off let it cool down for about 20 mins and drove it again. This time as I was driving on the freeway it stalled again. But no backfire or cough or anything. Any idea what it could be ?I'm waiting for my new ignition coil but at this point I'm pulling my hair!
Old Dec 2, 2022 | 07:31 AM
WKNDS's Avatar
WKNDS
You might get better response/feedback by starting a new thread, since
this one is 13 years old...
good luck,
T.
Old Dec 3, 2022 | 05:10 PM
Max Headflow's Avatar
Max Headflow
The head temps sensor is nothing more than a temp variable resistor. If the temp reading chances quickly, it's most likely a looks connection somewhere. It could be inside the sensor or inside the ECU but is more than likely a connector. Could be the one on the head or the one at the ECU.. Most common is the head. When doing reliability calculations for electronic equipment, a big factor that is included is the number of connectors in the system. Simply RnRing the connectors may have cured the issue.
Old Mar 31, 2023 | 03:52 PM
vaidas0429's Avatar
vaidas0429
1st Gear
Default Problem
Hi. Sorry for my bad english. I just bought 2013 sportster 72, and i have problem. Its disconnected temp sensor, and these wires is connected to other place.. this other connection is like secret ignition. But my temp.sensor is not working. If somebody understood what i need, maybe can tell me how to fix this problem? Thanks a lot!
Old Apr 1, 2023 | 02:22 PM
roussfam's Avatar
roussfam
Disconnect the secret ignition and reconnect the temp sensor.... That's all I got
WoodButcher66
2014-2024 Touring Models
May 31, 2021 06:08 PM
txphatboy
13
May 20, 2018 09:40 PM
longam
Aug 14, 2015 01:14 PM
rtbassmaster
Exhaust System Topics
May 9, 2013 07:14 PM
Virginia Squire
Feb 21, 2013 06:57 AM
