Accel SLM?
Old Aug 21, 2009 | 02:29 PM
Anezangl's Avatar
Anezangl
Question Accel SLM?
Have any of you seen the Accel SLM add in some of the bagger mags? Not a lot of info in the add space but claims to be totally self learning with all types of changes and upgrades. The kit for older bikes ( EFI ) even comes with a o2 sensor and a bung to weld to your pipes. I have a e-mail into their tech department but have not heard back as of yet. Is this thing like an automatic power commander type deal? Accel has been around a long time in the hotrod world. Their site says this SLM is new as of July.
Old Jan 12, 2010 | 10:35 PM
wglide85's Avatar
wglide85
For more information:
http://www.cyrilhuzeblog.com/2009/06...-plug-and-ride
Old Feb 27, 2010 | 09:21 AM
bensonjv's Avatar
bensonjv
I plan on using one with a cam swap this spring. I will resurrect this thread and post results.
Old Mar 3, 2010 | 07:13 PM
wglide85's Avatar
wglide85
I am also planning on installing an Accel module. I am finishing up a build and will have the bike started this weekend. Since my build is rather extensive, from the crankshaft up. I decided to update the map using the Super Tuner and will get it dyno tuned. After that I will install the module. I plan on doing another dyno run roughly one month after the install and see just what if anything changes.
Update with results at the time.
Old Apr 13, 2010 | 11:12 PM
wglide85's Avatar
wglide85
Default Accel Autotune SLM05 Installed
The initial break in map which was put in turned out to be very close to the final custom map. I ended up with 116/103, thought I’d be slightly higher, but very respectful. I installed the Accel Autotune SLM05 after the tune. I will put the bike back on the dyno after about one month, just for a comparison run.
sjbodie
13
May 30, 2022 12:47 PM
No U Glider
2014-2024 Touring Models
33
May 28, 2021 07:06 AM
ThisIsMe
Sep 30, 2015 06:59 AM
xwhyz1959
Feb 20, 2012 09:11 AM
DanDman
Dec 31, 2011 08:29 PM
