Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Just wondering how precise the actual settings that V&H provide with the fuel pak ? Although i know there is an increase in performance, Is there room for improvement from the pre set maps they provide ?
08 NT with Big Radius 2 into 2
HD Big Breather
Fuel Pak
I'm presently running V&H BSS + Arlen Ness BS stage 1 along with V&H FuelPack (on a 08 Custom). Good overall torque threw RPM range & occasionnal pop on decell...
FuelPack is a good & fairly inexpensive way to go if you don't plan to upgrade your ride any furthur than a basic stage 1 air filter & exhaust upgrade, using common known brands...
No personnal settings / adjustments are possible with V&H Fuelpack, all you have to do once the FP unit is connected inline with the OEM fuel manegment unit, is to dial in the preset code that matches your exhaust/air filter combination.
Preset codes are updated on a regular basis with new slip-ons & pipes combination.
As long you don't plan to play around cams / bore & stuff, Fuelpack is a good, reliable & fairly cheap way to go...........
