2002 Road King Classic - Ignition Problem?
It seems like it is not getting fuel and missing a cycle occasionally. It will pop and, when severe, will stall. Happens in all gears, but is most noticeable in first (mainly because thats when Im pulling into traffic J). Seems to happen most in humid, cool weather.
Any thoughts?
There's another thread here which suggests the throttle position sensor is a good candidate for the cause.
- Fuel pickup tube in the tank has a hole in it allowing air to get into the line.
- air leak in the induction path leaning out the mixture to the point of, well its just air.
- clogged MAP - providing false barametic readings, humidity causes pressure changes as gunk expands/contracts (no I don't believe this one either, but hey
)- partially clogged fuel filter. Gunk clogging at random moments.
- dirty A/C engine starved for air at throttle up.
- worn plugs, cracked plug - do random things as the heat expands and contracts the plug.
- worned plug wires, came issues as plug plus maybe fractured conducting path.
There are other possibilities. The better you are at reliably producing the problem, the easier it is to diagnose.
your mileage may vary.
...gene
Been fighting this thing for a year now. Runs fine then just misses a beat. Then will miss 2 beats or 3 then will run fine for a while.
Error code 24 showing front cylinder coil/open. Checked wires at injector but found no break. Power commander maybe? ecm?
Started with an occasional miss, begin to miss more often until it would hardly start or run. Using the enrichner would make it run better.
Found that the intake manifold was loose. One screw was missing and the other three were only finger tight.
You may also may have a poor battery connection or a failing head temperature sensor. These were the fault on a 2003 injected bike.
