Starter Kickback
Old Sep 7, 2009 | 09:18 PM
Trek's Avatar
Trek
Default Starter Kickback
I have a 2008 with Screaming eagle 103 kit 255 cam. I have 230 psi and 210 in the cylinders for pressure.
The engine kicks back against the starter about 1 out of 5 starts. Sounds horrible, like the thing is grinding metal on metal.
What are my options to fix this? Stronger starter? Then what one?
ACR? Expensive option.
Thanks
Old Sep 8, 2009 | 06:50 PM
firefighter156's Avatar
firefighter156
Compression releases installed in the heads should solve ur problem. Or upgrade ur starter to a more heavy duty model.
Old Sep 8, 2009 | 10:09 PM
Trek's Avatar
Trek
I've decided to upgrade to a slightly more powerful starter. From a 1.2 kw to a 1.4 kw. (I don't rmember the brand name..something with Tech in the name.) I talked to my local mechanic today and he felt that would be a better choice for my application. I hope so.....really hated the idea of taking the heads off again and going through that whole process.
Old Sep 9, 2009 | 10:22 AM
1997bagger's Avatar
1997bagger
I have cylinder pressure as high as yours and would trash a stock starter clutch, put a 1.4 allballs and bigger cables on, has been trouble free for 2 years.
LDB187
Mar 3, 2014 08:50 PM
Blake11
Feb 26, 2013 04:44 PM
dogbone
Oct 6, 2011 10:14 AM
bikersurgeon
May 29, 2011 09:28 PM
Bluesrider
Jan 6, 2010 11:32 AM
