Injector pulse width vs.temperature
Old Jun 16, 2006 | 02:26 PM
gbm's Avatar
gbm
Default Injector pulse width vs.temperature
I have an '06 Dyna. I am wondering how much, if any, the injector pulse width is effected by ambiant and engine temperature. An old hot rod trick is to fool the ECM into sensing that things are a lot colder than they really are which subsequently could fatten up the mixture and/or alter the ignition curve. This could been done by substituting fixed resistors for the variable ones of the IAT and ET sensors. Perhaps.
Old Jun 18, 2006 | 03:23 AM
wlbowers's Avatar
wlbowers
Default RE: Injector pulse width vs.temperature
You will **** it off and make it throw error codes.
Old Jun 18, 2006 | 05:37 PM
bobcowan's Avatar
bobcowan
It will affect the pulse width dramatically, although somewhat unpredicatbly. You could simply move the IAT sensor out to the filter base plate. But when you do that sort of thing, you're telling the computer that the air is always colder than it is. Sometimes that causes an overly rich mixture; and that's a bad thing.
You could try it ans see how it goes, it's free. If it doesn't run well in all situations, you should get a real tuner.
Old Jun 20, 2006 | 10:18 AM
gbm's Avatar
gbm
Thanks much for the sound advice from Lee and Bob, I really appreciate it. Last time I pissed off a 'puter it puked.
SmittyFXDL
Jan 29, 2016 06:16 PM
Ben Marantan
Jan 31, 2013 11:38 AM
cybricon
Exhaust System Topics
Jun 30, 2010 09:05 PM
nigelgeast
Sep 11, 2008 12:09 PM
mikeurig
May 28, 2008 09:19 PM
