strange electrical issue
Old Jul 5, 2006 | 01:47 PM
COFFESLINGER's Avatar
COFFESLINGER
Default strange electrical issue
Turned my bike on today and half of it worked. The bike fired yet the only things electrical that would work were the headlamp, tail lamp, small readout on odometer that says you are in neutral. The speedometer, turnsignals, and horn would not work. No idea what this problem is. The only thing strange it did was once will trying to fire it both turn signals on the speedometer readout began to blink like the bike had hazzards on. Any feedback would be helpful. I recently installed a new clutch cable clamp and a new resevoir cover on my handlebars but the only thing that required was adjusting the clutch nothing else.
05 dyna wide glide
Old Jul 5, 2006 | 02:18 PM
liltrk's Avatar
liltrk
Default RE: strange electrical issue
The items you mention are all on the same fuse. Something blew the fuse, but can't tell what. The stuff you did should not be a problem.
There have also been issues with ignition switches but I think only on the 06 models.
Old Jul 5, 2006 | 02:31 PM
COFFESLINGER
Began to think that myself. Pulled the cover off of the fuse box and figured out by pulling each one out which had no effect on what was working on the bike. I going to replace the fuses see if it works and give it a while before i take it to the stealership. Thanks for the info much appreciated.
onthebrink11
Sep 11, 2013 04:17 PM
OsoFat
Dec 11, 2008 09:25 PM
kg4epz
Oct 31, 2008 09:22 PM
03sporty
Feb 12, 2007 01:44 PM
dragsta
Sep 18, 2005 06:29 PM
