voltage problem
Old Nov 22, 2009 | 06:22 PM
davidpisano's Avatar
davidpisano
Default voltage problem
91 Electra glide shows 10 volts on meter. Where should I be looking?
Thanks for the help.
Dave P
Old Nov 22, 2009 | 07:49 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Is that 10vdc at the battery while at rest or while running, the gauge in the fairing, or at the Voltage Regulator????
Old Nov 23, 2009 | 07:01 PM
davidpisano
The 10vdc is showing at the guage on the fairing while running at idle speed. It does not increase when engine speed in increased. Tail light, brake light and directional lights also do not work at idle. I connected a charger to battery terminals while running and brought the guage to 12 volts. Lights did work. I would like to pin point problem, rather than buying not needed parts.
Thanks
Old Nov 23, 2009 | 08:34 PM
RCB's Avatar
RCB
Check battery connections. How old is the battery? Have the battery load tested.
Old Nov 23, 2009 | 08:48 PM
Shovelhead Bob
You need to start at the battery voltage, then load test, then starter draw test, after that you need to look at voltage at idle and at 3000 rpm.
The following specs are off the top of my head, your Electrical Diagnostics manual will have the EXACT specs...
Battery should be at 12.3 vdc at static
Voltage should go no lower than 10 vdc during cranking
Battery voltage at idle should be 12.5-13.5 vdc
Battery voltage at 3k rpm should be around 13.8-14.4 vdc
Stator should not be grounded out
Stator should produce about 35-45 vac at 3k rpm
You will need to pinpoint which component failed... you can always open up the primary inspection plate, and if you get a really bad, burning smell, your stator has failed.... no need for more testing...
spalmer1214
May 22, 2021 03:34 PM
Steinimal
Electrical/Lighting/Alarm
May 28, 2017 04:26 PM
Inky
Aug 12, 2015 07:50 AM
LukeDukefromGA
Oct 26, 2011 09:36 PM
FLHXXHLF
Feb 4, 2010 06:44 PM
