kill button NOT SWITCH wiring
Old Jan 17, 2010 | 11:48 AM
fullmonty8's Avatar
fullmonty8
1st Gear
Default kill button NOT SWITCH wiring
I purchased a new chopper with hd factory controls on them that are black. I purchased a set of new chrome controls with buttons on them only. Open circut buttons until it is pushed to connect like a starter button. I have the srarter hooked up, and the horn. I do not know how to go from a continous circut switch which just interrupts the flow circut, to a kill button. I have some ideas but don't want to damage my ignition. I have no points, ... help thanks Rich
Last edited by fullmonty8; Jan 17, 2010 at 12:14 PM. Reason: I have no points sorry
Old Jan 17, 2010 | 12:12 PM
qtrracer's Avatar
qtrracer
Magneto has points , at least all the ones (3) I have had did. 2 wire kill button grounded back underneath the tank area is how I always did it. Watch the gap on the points as they wear the gap starts to close up and the engine gets very hard to start and will run poorly at lower rpms. Had a 113" evo motored rigid frame kick only no battery magneto built chopper , so I was very in tune with that one on all the possible starting issues.
Old Jan 17, 2010 | 12:17 PM
fullmonty8's Avatar
fullmonty8
1st Gear
I understand to ground one end of the button wire but the other end goes where. I run a battery system like a car and both sides of coils are hot when key is turned on.
Dudepants
May 23, 2018 02:33 PM
SugsPa
Jun 2, 2017 08:21 AM
Edward Brown
Shovelhead
Jan 28, 2016 02:04 PM
carlgrover
Shovelhead
May 18, 2014 08:57 PM
laythss
EVO
Aug 9, 2010 09:59 PM
