codes
Old Aug 27, 2010 | 05:13 PM
Mr. Wizard's Avatar
Mr. Wizard
Originally Posted by AbnMP13
I called Jamie at Fuel Moto and he stated to leave the O2 sensors unplugged and suggested I check all the pins on the PCV. Gonna go do that now.
AAAAHHHHH... You have a PCV. Makes more sense now.
Yes you must unplug your 02 sensors and plug the 02 eliminators in. If you can't find a pin or wire bad then look for one of your eliminators to be defective.
Old Aug 27, 2010 | 07:39 PM
AbnMP13's Avatar
AbnMP13
Didn't work; it also throws code 61154 under the first S. Couldn't find that one on the forums.
Old Aug 27, 2010 | 08:19 PM
Mr. Wizard's Avatar
Mr. Wizard
The only 1154 code I know of is B1154. That is clutch switch short to ground.
Old Aug 28, 2010 | 06:15 AM
AbnMP13's Avatar
AbnMP13
LOL I'll bet you seen the light! As soon as I read clutch wire I jumped up and ran outside to work on my bike. Last week I attempted to put chrome control covers on my bike but realized they had sent the wrong ones; when reinstalling them I had pinched a wire.
Gonna check to see if the light comes on again when I head to work today. Thanks in advance for all the help.
Old Aug 28, 2010 | 06:32 AM
Mr. Wizard's Avatar
Mr. Wizard
Your welcome. Here is a list of the 2010 codes if you need them again.
2010 Touring Models - Electronic Diagnostic - Diagnostic Trouble Codes (DTC)
2010_DTC_Codes -.pdf
Diagnostic Trouble Codes (DTCs) (TABLE 1)
DTC: B0562
FAULT CONDITION: Battery Voltage Low
SOLUTION: 3.6 DTC B0563, P0562, P0563
DTC: B0563
FAULT CONDITION: Battery Voltage High
PRIORITY ORDER: 138
DTC: B1004
FAULT CONDITION: Fuel Level Sending Unit Low
PRIORITY ORDER: 145
SOLUTION: 4.2 DTC B1004, B1005
DTC: B1005
FAULT CONDITION: Fuel Level Sending Unit High/Open
PRIORITY ORDER: 146
DTC: B1006
FAULT CONDITION: Accessory Line Overvoltage
PRIORITY ORDER: 143
SOLUTION: 3.7 DTC B1006, B1007
DTC: B1007
FAULT CONDITION: Ignition Line Overvoltage
PRIORITY ORDER: 142
DTC: B1008
FAULT CONDITION: Trip Odometer Reset Switch Closed
PRIORITY ORDER: 144
SOLUTION: 4.3 DTC B1008
DTC: B1121
FAULT CONDITION: Left Turn Output Fault
PRIORITY ORDER: 129
SOLUTION: 5.11 DTC B1121,B1122,B1123,B1124,B1125,B1126
DTC: B1122
FAULT CONDITION: Right Turn Output Fault
PRIORITY ORDER: 130
DTC: B1123
FAULT CONDITION: Left Turn Signal short-to-ground
PRIORITY ORDER: 131
DTC: B1124
FAULT CONDITION: Right Turn Signal short-to-ground
PRIORITY ORDER: 132
DTC: B1125
FAULT CONDITION: Left Turn Signal short-to-voltage
PRIORITY ORDER: 133
DTC: B1126
FAULT CONDITION: Right Turn Signal short-to-voltage
PRIORITY ORDER: 134
DTC: B1131
FAULT CONDITION: Alarm Output Low
PRIORITY ORDER: 139
SOLUTION: 5.18 DTC B1131,B1132
DTC: B1132
FAULT CONDITION: Alarm Output High
PRIORITY ORDER: 140
DTC: B1134
FAULT CONDITION: Starter Relay Output High
PRIORITY ORDER: 128
SOLUTION: 5.19 DTC B1134
DTC: B1135
FAULT CONDITION: Accelerometer Fault
PRIORITY ORDER: 23
SOLUTION: 5.12 DTC B1135,B1136,B1141,B1142
DTC: B1136
FAULT CONDITION: Accelerometer tip-over self-test fault
PRIORITY ORDER: 24
DTC: B1141
FAULT CONDITION: Ignition Switch open/low
PRIORITY ORDER: 141
DTC: B1142
FAULT CONDITION: Internal Fault
PRIORITY ORDER: 22
DTC: B1143
FAULT CONDITION: Security antenna short-to-ground
PRIORITY ORDER: 135
SOLUTION: 5.20 DTC B1143,B1144,B1145
DTC: B1144
FAULT CONDITION: Security antenna short-to-battery
PRIORITY ORDER: 136
DTC: B1145
FAULT CONDITION: Security antenna open
PRIORITY ORDER: 137
DTC: B1151
FAULT CONDITION: Sidecar BAS short to ground
PRIORITY ORDER: 25
SOLUTION: See Trike or Sidecar supp manual
DTC: B1152
FAULT CONDITION: Sidecar BAS short to battery
PRIORITY ORDER: 26
DTC: B1153
FAULT CONDITION: Sidecar BAS Out of Range
PRIORITY ORDER: 27
DTC: B1154
FAULT CONDITION: Clutch switch short-to-ground
PRIORITY ORDER: 28
SOLUTION: 5.21 DTC B1154,B1155
DTC: B1155
FAULT CONDITION: Neutral Switch short-to-ground
PRIORITY ORDER: 29
DTC: C0562
FAULT CONDITION: System Voltage Low
PRIORITY ORDER: 111
SOLUTION: 3.6 DTC B0563,P0562,P0563
DTC: C0563
FAULT CONDITION: System Voltage High
PRIORITY ORDER: 112
DTC: C1014
FAULT CONDITION: ECU internal solid state relay fault
PRIORITY ORDER: 105
SOLUTION: 7.15 DTC C1014,C1055-C1066,C1118,C1121
DTC: C1017
FAULT CONDITION: Pump Motor Power Circuit Open Fault
PRIORITY ORDER: 110
SOLUTION: 7.2 DTC C1017,C1018
DTC: C1018
FAULT CONDITION: Pump motor ground high resistance fault
PRIORITY ORDER: 109
DTC: C1021
FAULT CONDITION: Front wheel speed sensor always equals zero kph
PRIORITY ORDER: 115
SOLUTION: 7.3 DTC C1021,C1023
DTC: C1023
FAULT CONDITION: Rear wheel speed sensor always equals zero kph
PRIORITY ORDER: 116
DTC: C1025
FAULT CONDITION: Front wheel speed sensor signal intermittent
PRIORITY ORDER: 117
SOLUTION: 7.4 DTC C1025,C1027,C1206,C1208
DTC: C1027
FAULT CONDITION: Rear wheel speed sensor signal intermittent
PRIORITY ORDER: 118
DTC: C1032
FAULT CONDITION: Front wheel speed sensor circuit open or shorted
PRIORITY ORDER: 113
SOLUTION: 7.5 DTC C1032,C1034
DTC: C1034
FAULT CONDITION: Rear wheel speed sensor circuit open or shorted
PRIORITY ORDER: 114
DTC: C1042
FAULT CONDITION: Pump motor open
PRIORITY ORDER: 107
SOLUTION: 7.6 DTC C1042,C1043
DTC: C1043
FAULT CONDITION: Pump motor stalled
PRIORITY ORDER: 108
DTC: C1055
FAULT CONDITION: ECU internal fault
PRIORITY ORDER: 96
DTC: C1056
FAULT CONDITION: ECU internal fault - sold state relay shorted ON
PRIORITY ORDER: 97
DTC: C1057
FAULT CONDITION: ECU internal fault - solid state relay shorted to ground
PRIORITY ORDER: 98
DTC: C1061
FAULT CONDITION: ECU internal fault - front apply solenoid
PRIORITY ORDER: 99
DTC: C1062
FAULT CONDITION: ECU internal fault - front release solenoid
PRIORITY ORDER: 100
DTC: C1065
FAULT CONDITION: ECU internal fault - rear apply solenoid
PRIORITY ORDER: 101
DTC: C1066
FAULT CONDITION: ECU internal fault - rear release solenoid
PRIORITY ORDER: 102
DTC: C1094
FAULT CONDITION: Front brake switch always on
PRIORITY ORDER: 121
SOLUTION: 7.7 DTC C1094
DTC: C1095
FAULT CONDITION: Front brake switch open
PRIORITY ORDER: 122
SOLUTION: 7.8 DTC C1095
DTC: C1118
FAULT CONDITION: ECU internal fault - front apply solenoid correlation
PRIORITY ORDER: 103
DTC: C1121
FAULT CONDITION: ECU internal fault - rear apply solenoid correlation
PRIORITY ORDER: 104
DTC: C1151
FAULT CONDITION: Front wheel ABS release too long
PRIORITY ORDER: 126
SOLUTION: 7.9 DTC C1151
DTC: C1153
FAULT CONDITION: Rear wheel ABS release too long
PRIORITY ORDER: 127
SOLUTION: 7.10 DTC C1153
DTC: C1158
FAULT CONDITION: Calibration programming required
PRIORITY ORDER: 106
SOLUTION: 7.11 DTC C1158
DTC: C1206
FAULT CONDITION: Front wheel speed sensor frequency out of range
PRIORITY ORDER: 119
DTC: C1208
FAULT CONDITION: Rear wheel speed sensor frequency out of range
PRIORITY ORDER: 120
DTC: C1212
FAULT CONDITION: Front or Rear brake not applied with decel
PRIORITY ORDER: 125
SOLUTION: 7.12 DTC C1212
DTC: C1214
FAULT CONDITION: Rear brake switch always on
PRIORITY ORDER: 123
SOLUTION: 7.13 DTC C1214
DTC: C1216
FAULT CONDITION: Rear brake switch open
PRIORITY ORDER: 124
SOLUTION: 7.14 DTC C1216
DTC: P0031
FAULT CONDITION: O2 heater low/open
PRIORITY ORDER: 82
SOLUTION: 6.7 DTC P0031,P0032,P0131,P0132,P0134,P0151,P0152,P0154
DTC: P0032
FAULT CONDITION: O2 heater shorted/high
PRIORITY ORDER: 82
DTC: P0106
FAULT CONDITION: MAP Sensor Rate of Range Error
DTC: P0107
FAULT CONDITION: Map Sensor Open/Low
PRIORITY ORDER: 19
SOLUTION: 6.4 DTC P0107,P0108,P0112,P0113
DTC: P0108
FAULT CONDITION: Map Sensor High
PRIORITY ORDER: 20
DTC: P0112
FAULT CONDITION: IAT Sensor Voltage Low
PRIORITY ORDER: 58
DTC: P0113
FAULT CONDITION: IAT Sensor Voltage Open/High
PRIORITY ORDER: 59
DTC: P0117
FAULT CONDITION: ET Sensor Voltage Low
PRIORITY ORDER: 56
SOLUTION: 6.5 DTC P0117,P0118
DTC: P0118
FAULT CONDITION: ET Sensor Voltage Open/High
PRIORITY ORDER: 57
DTC: P0120
FAULT CONDITION: Throttle position sensor 1 range error
PRIORITY ORDER: 38
SOLUTION: 6.6 DTC P0120,P0122,P0123,P0220,P0222,P0223
DTC: P0122
FAULT CONDITION: TP Sensor Open/Low
PRIORITY ORDER: 40
DTC: P0123
FAULT CONDITION: TP Sensor High
PRIORITY ORDER: 41
DTC: P0131
FAULT CONDITION: Front O2 sensor low (lean)
PRIORITY ORDER: 84
DTC: P0132
FAULT CONDITION: Front O2 sensor high (rich)
PRIORITY ORDER: 86
DTC: P0134
FAULT CONDITION: Front O2 sensor open/not responding
PRIORITY ORDER: 88
DTC: P0151
FAULT CONDITION: Rear O2 sensor low (lean)
PRIORITY ORDER: 85
DTC: P0152
FAULT CONDITION: Rear O2 sensor high (rich)
PRIORITY ORDER: 87
DTC: P0154
FAULT CONDITION: Rear O2 sensor open/not responding
PRIORITY ORDER: 89
DTC: P0220
FAULT CONDITION: Throttle position sensor 2 range error
PRIORITY ORDER: 39
SOLUTION: 6.6 DTC P0120,p0122,P0123,P0220,P0222,P0223
DTC: P0222
FAULT CONDITION: Throttle position sensor 2 low/open
PRIORITY ORDER: 42
DTC: P0223
FAULT CONDITION: Throttle position sensor 2 high
PRIORITY ORDER: 43
DTC: P0261
FAULT CONDITION: Front Injector Open/Low
PRIORITY ORDER: 66
SOLUTION: 6.8 DTC P0261,P0262,P0263,P0264
DTC: P0262
FAULT CONDITION: Front Injector High
PRIORITY ORDER: 68
DTC: P0263
FAULT CONDITION: Rear Injector Open/Low
PRIORITY ORDER: 67
DTC: P0264
FAULT CONDITION: Rear Injector High
PRIORITY ORDER: 69
DTC: P0373
FAULT CONDITION: CKP Sensor Intermittent
PRIORITY ORDER: 18
SOLUTION: 6.9 DTC P0373,P0374
DTC: P0374
FAULT CONDITION: CKP Sensor Synch Error
PRIORITY ORDER: 21
DTC: P0444
FAULT CONDITION: Purge control open/low
PRIORITY ORDER: 77
SOLUTION: 6.10 DTC P0444,P0445
DTC: P0445
FAULT CONDITION: Purge control high
PRIORITY ORDER: 78
DTC: P0501
FAULT CONDITION: VSS Low
PRIORITY ORDER: 72
SOLUTION: 6.11 DTC P0501,P0502
DTC: P0502
FAULT CONDITION: VSS High/Open
PRIORITY ORDER: 73
DTC: P0505
FAULT CONDITION: Loss of Idle Sped Control
PRIORITY ORDER: 76
SOLUTION: 6.12 DTC P0505
DTC: P0562
PRIORITY ORDER: 70
DTC: P0563
PRIORITY ORDER: 71
SOLUTION: 3.6 BTC B0563,P0562,P0563
DTC: P0572
FAULT CONDITION: Brake switch low
PRIORITY ORDER: 55
SOLUTION: 6.13 DTC P0572
DTC: P0577
FAULT CONDITION: Cruise control input high
PRIORITY ORDER: 93
SOLUTION: 5.4 DTC P0577
DTC: P0602
FAULT CONDITION: Calibration Memory Error
DTC: P0603
FAULT CONDITION: ECM EEPROM Error
PRIORITY ORDER: 2
SOLUTION: 6.14 DTC P0603,P0605
DTC: P0604
FAULT CONDITION: RAM Failure
DTC: P0605
FAULT CONDITION: ECM Flash Error
PRIORITY ORDER: 1
DTC: P0607
FAULT CONDITION: Converter Error
DTC: P0641
FAULT CONDITION: 5V ref 1 out of range
PRIORITY ORDER: 16
SOLUTION: 6.15 DTC P0641,P0651
DTC: P0651
FAULT CONDITION: 5V ref 2 out of range
PRIORITY ORDER: 17
DTC: P0661
FAULT CONDITION: Intake solenoid low/open
PRIORITY ORDER: 48
DTC: P0662
FAULT CONDITION: Intake solenoid high/shorted
PRIORITY ORDER: 49
DTC: P1001
FAULT CONDITION: System Relay Coil Open/Low
PRIORITY ORDER: 12
SOLUTION: 6.16 DTC P1001,P1002,P1003,P1004
DTC: P1002
FAULT CONDITION: System relay Coil High/Shorted
PRIORITY ORDER: 11
DTC: P1003
FAULT CONDITION: System relay Contacts Open
PRIORITY ORDER: 10
DTC: P1004
FAULT CONDITION: System Relay Contacts Closed
PRIORITY ORDER: 13
DTC: P1009
FAULT CONDITION: Incorrect Password
PRIORITY ORDER: 14
SOLUTION: 6.17 DTC P1009,P1010
DTC: P1010
FAULT CONDITION: Missing Password
PRIORITY ORDER: 15
DTC: P1270
FAULT CONDITION: Twistgrip position sensor 2 A/D validation error
PRIORITY ORDER: 31
SOLUTION: 6.18 DTC P1270
DTC: P1351
FAULT CONDITION: Front Ignition Open/Low
PRIORITY ORDER: 60
SOLUTION: 6.19 DTC P1351,P1352,P1354,P1355
DTC: P1352
FAULT CONDITION: Front Ignition Coil High/Shorted
PRIORITY ORDER: 62
DTC: P1353
FAULT CONDITION: Front Cylinder No Combustion
PRIORITY ORDER: 75
SOLUTION: 6.20 DTC P1353,P1356,P1357,P1358
DTC: P1354
FAULT CONDITION: Rear Ignition Coil Open/Low
PRIORITY ORDER: 61
DTC: P1355
FAULT CONDITION: Rear Ignition Coil High/Shorted
PRIORITY ORDER: 63
DTC: P1356
FAULT CONDITION: Rear Cylinder No Combustion
PRIORITY ORDER: 74
DTC: P1357
FAULT CONDITION: Intermittent Secondary Front
PRIORITY ORDER: 64
DTC: P1358
FAULT CONDITION: Intermittent Secondary Rear
PRIORITY ORDER: 65
DTC: P1475
FAULT CONDITION: Exhaust position actuation error
PRIORITY ORDER: 79
SOLUTION: 6.21 DTC P1475,P1477,P1478
DTC: P1477
FAULT CONDITION: Exhaust actuator low/open
PRIORITY ORDER: 80
DTC: P1478
FAULT CONDITION: Exhaust actuator hight/shorted
PRIORITY ORDER: 81
DTC: P1501
FAULT CONDITION: JSS low
PRIORITY ORDER: 53
SOLUTION: 6.22 DTC P1501,P1502
DTC: P1502
FAULT CONDITION: JSS high
PRIORITY ORDER: 54
DTC: P1510
FAULT CONDITION: Throttle actuator control limited performance
PRIORITY ORDER: 90
SOLUTION: 6.23 DTC P1510,P1511,P1512
DTC: P1511
FAULT CONDITION: Throttle actuator limited power management mode
PRIORITY ORDER: 91
DTC: P1512
FAULT CONDITION: Throttle actuator control forced idle mode
PRIORITY ORDER: 92
DTC: P1514
FAULT CONDITION: Throttle actuator control system airflow fault
PRIORITY ORDER: 51
SOLUTION: 6.24 DTC P1514
DTC: P1600
FAULT CONDITION: TCA module - internal fault
PRIORITY ORDER: 30
SOLUTION: 6.25 DTC P1600
DTC: P1655
FAULT CONDITION: ACR solenoid low
PRIORITY ORDER: 94
SOLUTION: 6.26 DTC P1655,P1656
DTC: P1656
FAULT CONDITION: ACR solenoid high
PRIORITY ORDER: 95
DTC: P2100
FAULT CONDITION: Throttle actuator control motor circuit / open
PRIORITY ORDER: 46
SOLUTION: 6.27 DTC P2100,P2101,P2102,P2103
DTC: P2101
FAULT CONDITION: Throttle actuator control motor circuit - range error
PRIORITY ORDER: 47
DTC: P2102
FAULT CONDITION: Throttle actuator control motor circuit - low
PRIORITY ORDER: 48
DTC: P2103
FAULT CONDITION: Throttle actuator control motor circuit - high
PRIORITY ORDER: 49
DTC: P2105
FAULT CONDITION: Throttle actuator control system - forced engine shutdown
PRIORITY ORDER: 52
SOLUTION: 6.28 DTC P2105,P2107
DTC: P2107
FAULT CONDITION: Throttle actuator control module processor
PRIORITY ORDER: 32
DTC: P2119
FAULT CONDITION: Throttle actuator control system - throttle return error
PRIORITY ORDER: 45
SOLUTION: 6.29 DTC P2119
DTC: P2122
FAULT CONDITION: Twistgrip position sensor 1 low/open
PRIORITY ORDER: 33
SOLUTION: 6.30 DTC P2122,P2123,P2127,P2128
DTC: P2123
FAULT CONDITION: Twistgrip position sensor 1 high
PRIORITY ORDER: 34
DTC: P2127
FAULT CONDITION: Twistgrip position sensor 2 low/open
PRIORITY ORDER: 35
DTC: P2128
FAULT CONDITION: Twistgrip position sensor 2 high
PRIORITY ORDER: 36
DTC: P2135
FAULT CONDITION: Throttle position sensor correlation error
PRIORITY ORDER: 44
SOLUTION: 6.31 DTC P2135,P2138
DTC: P2138
FAULT CONDITION: Twistgrip position sensor correlation error
PRIORITY ORDER: 37
DTC: P2176
FAULT CONDITION: Throttle actuator control system - closed position not learned
PRIORITY ORDER: 50
SOLUTION: 6.32 DTC P2176
DTC: U1016
FAULT CONDITION: Loss of ECM Serial Data
PRIORITY ORDER: 7
SOLUTION: 2.3 DTC U1016,U1040,U1064,U1097,U1255
DTC: U1040
FAULT CONDITION: Loss of ABS serial data
PRIORITY ORDER: 8
DTC: U1064
FAULT CONDITION: Loss of TSM/TSSM/HFSM Serial Data
PRIORITY ORDER: 6
DTC: U1097
FAULT CONDITION: Loss of Speedometer Serial data
PRIORITY ORDER: 5
DTC: U1255
FAULT CONDITION: Missing response at module
PRIORITY ORDER: 9
DTC: U1300
FAULT CONDITION: Serial Data Low
PRIORITY ORDER: 3
SOLUTION: 2.4 DTC U1300,U3101 OR BUS ERROR
DTC: U1301
FAULT CONDITION: Serial Data Open/High
PRIORITY ORDER: 4
Radio Diagnostics:
The radio DTCs are retrieved through the radio and displayed on the radio display.
1. Press eject button to remove CD from unit.
2. While pressing and holding any two softkeys (buttons 1- 6), turn ignition switch "ON" until radio diagnostic display appears.
Radio Diagnostic Trouble Codes (RDTCs) (TABLE 2)
DTC: B0563
FAULT-SET CONDITION: t>=15 sec. V>= 16 Volts
FAULT-CLEAR CONDITION T=TIME; R=RESISTANCE: Normal range for t>= 15 sec
DTC: B2006
FAULT CONDITION: Radio switch stuck or open
DTC: B2007
FAULT CONDITION: Handlebar switch shorted high
FAULT-SET CONDITION: Ignition ON after Ignition OFF for at least 10 sec., t=instantaneous
FAULT-CLEAR CONDITION T=TIME; R=RESISTANCE: Normal range for t>=15 sec *
DTC: B2008
FAULT CONDITION: Handlebar switch shorted low
FAULT-CLEAR CONDITION T=TIME; R=RESISTANCE: Normal range for t>=15 sec*
DTC: B2009
FAULT CONDITION: Handlebar switch stuck or open
DTC: B2010
FAULT CONDITION: Passenger switch shorted high
DTC: B2011
FAULT CONDITION: Passenger switch shorted low
DTC: B2012
FAULT CONDITION: Passenger switch stuck or open
DTC: B2016
FAULT CONDITION: Front speakers shorted
FAULT-SET CONDITION: R<1.5 Ohms tested once per ignition cycle R>1.0 Ohm when setup as line out ignition ON after Ignition OFF for at least 10 sec., t=instantaneous
FAULT-CLEAR CONDITION T=TIME; R=RESISTANCE: R>1.5 Ohms tested once per ignition cycle
DTC: B2017
FAULT CONDITION: Front speakers open
FAULT-SET CONDITION: R>100 Ohms tested once per ignition cycle ignition ON after Ignition OFF for at least 10 sec., t=instantaneous
FAULT-CLEAR CONDITION T=TIME; R=RESISTANCE: R>100 Ohms tested once per ignition cycle
DTC: B2018
FAULT CONDITION: Front speakers shorted to ground
DTC: B2019
FAULT CONDITION: Front speakers shorted to battery
DTC: B2020
FAULT CONDITION: Rear speakers shorted
DTC: B2021
FAULT CONDITION: Rear speakers open
FAULT-CLEAR CONDITION T=TIME; R=RESISTANCE: R<100 Ohms tested once per ignition cycle
DTC: B2022
FAULT CONDITION: Rear Speakers shorted to ground
DTC: B2023
FAULT CONDITION: Rear speakers shorted to battery
* Ignition ON after Ignition OFF for at least 10 seconds.
Calibration Data:
I = Intercom: 0=Disabled; 1=Enabled
J = J1850: 0=Disabled; 1=Enabled
V = Vehicle Speed Input: 0=Low; 1=High (1998-2005 Only)
H = Hardware Revision
Old Jun 30, 2017 | 07:52 PM
burf36's Avatar
burf36
Stage IV
can anyone tell me what error code 1040 means as well as PN 74692-10 when I have this on my speedometer read out is that the part number of a component that has failed?
Old Jun 30, 2017 | 08:47 PM
jbarr1's Avatar
jbarr1
See post above--- U1040 is loss of abs serial data.
74692-10 is the speedo part number.
Old Jul 1, 2017 | 07:09 AM
2009blackpearle's Avatar
2009blackpearle
Default what timing
I posted this 7 years ago . I just had the motor apart last Cpl weeks and got about 20 codes, took pictures of codes, then reset them all , didn't come back , its just from having lots of things unplugged and turning key on in my case to hear radio while I worked on the motor, this time I'm coping and pasting all the codes to Microsoft word. I had acr's in mva heads but have stock ones on for now until I get the cylinder bored to 107 and get a different set of heads. turned acr's off with race tuner, no acr missing code either.
I had to use mozilla the copy and paste for some reason ie explorer wouldnt let me right click for copy option , in case anyone else tries to copy the list.
stevefxdi
Apr 10, 2011 09:56 PM
tanglefootrgu
Mar 23, 2009 08:51 PM
sparky_mo
Jul 21, 2007 09:28 AM
tigger01291958
Apr 16, 2006 11:03 AM
srigas
Apr 10, 2006 04:52 PM
