every time
Old Aug 11, 2006 | 06:50 PM
triker uk's Avatar
triker uk
Default every time
why is it every time you disconect the battery on my dyna dont know about others but replaced tcm and put new battery on went through learn procedure as described on fact sheet fired straight up then a short while later had a problem with starter motor, so disconected battery took off starter damm did not need to do that as where the problem was, it was on the other side drain oil out of case , took off case, take off clutch ,just to get to coupling that jack shaft runs through and pinion gear as they were a bit worn , put new bits on ,went to fire up bike and nothing what a bummer , had to do the relearn procedure all over again just because battery was disconected .[:'(][:'(][:'(][:'(]
user 6485939
May 26, 2018 01:52 PM
BigBoreNighttrain
Dec 14, 2016 04:05 PM
cmosentine
Sep 25, 2013 12:32 AM
Rynb15
Dec 22, 2008 12:46 PM
djprey
Jun 26, 2007 12:36 PM
